I Can't Find The Screw On My Ecu!
Old Mar 11, 2003 | 02:58 AM
glimmer1's Avatar
I have a 99 maxima SE L . I am trying do a fault code diagnosis using the instructions in the post at the top of the 4th gen page.
I can't seem to find the screw. I attached a link to a photo.
It must be recessed but I don't want to reach around in there with a screw driver if I can't see the screw.
Is there anyone out there with a 99 maxima that has done this, any help would be great.
Click this link to see a photo of the ECU
http://ww-models.com/graphics/ecu2.jpg
Old Mar 11, 2003 | 03:16 AM
bdgatt's Avatar
You're right where you need to be, it's in the hole behind the broken tape (you probably knew that) but it's sunken down a bit and it's a small white plastic screw you need tiny screwdriver and kid gloves.
Old Mar 11, 2003 | 03:28 AM
looney662's Avatar
http://www.brianv.net/mods/ecu/ECU2.jpg
Go to http://www.brianv.net for all the info about resetting your ecu.
Old Mar 11, 2003 | 04:54 AM
glimmer1's Avatar
Thanks for the info.
How did you see the tiny white plastic screw underneath? I looked and looked and can't see anything. How do you know the position of the screw if you can't see it? I guess I could probably feel it.
It also says something about the idle speed adjust. Do I have to worry about that?
Old Mar 11, 2003 | 05:10 AM
glimmer1's Avatar
[QUOTE]Originally posted by looney662
[B]http://www.brianv.net/mods/ecu/ECU2.jpg
The ECU is different on the 99 Max the screw is recessed and hard to find, check out the photo on my post and compare it to the photo link that you gave me, you will see what I mean. That's why I was confused.
Old Mar 11, 2003 | 05:13 AM
fisher's Avatar
On my 99, the small white plastic screw is recessed off to the left side. You need to use a real small screwdriver, the type used for eyeglasses, to turn the screw. Be very gentle, and you be able to feel the stops when turning right or left. I know its tough to see and I used a strong flashlight to get a good idea where that white screw is located. As to the sticker about idle speed, just disregard that.
Old Mar 11, 2003 | 05:20 AM
fisher's Avatar
Just saw your picture, looks like mine. My white screw is recessed and located downward to the left. I can access it by inserting the screw driver on an angle.
Old Mar 11, 2003 | 05:37 AM
Eric99SE's Avatar
After looking at the picture you posted, I'm not so sure you didn't break off the screw. Believe me, it's possible...
After I broke mine off, I had to remove the ECU, open it up and try to repair. When I realized that is not possible, I wired in a simple two position toggle switch which does the same things as the screw used to. I can now just reach down and flick the switch back and forth to read codes and re-set. Not pretty, but it works.
I hope for your sake, however, that you didn't break it. I too have a 99 SE.
Good luck,
Eric99SE
Old Mar 11, 2003 | 05:43 AM
glimmer1's Avatar
I just broke a hole through the plastic...
I did't use any tools yet.
Old Mar 11, 2003 | 06:34 AM
glimmer1's Avatar
Did you have a metal or a white plastic screw?
I am just curious.
Old Mar 11, 2003 | 09:35 AM
d_hammmer's Avatar
I am just curious.
I think I see it at the 4 o'clock position
It 's a gray slotted plastic screw
Old Mar 11, 2003 | 09:56 AM
ecapati's Avatar
also have a 99 SE and just reset the ECU for the first time this past weekend. mine had a white plastic phillips head positioned around the bottom left. you'll need a small phillips screw driver used for electronic repairs. forget about a normal flat head screwdriver, it's too big. also, it requires very little pressure to turn in either direction.
hope this helps!
Old Mar 11, 2003 | 11:52 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
i have the same car, and i was able to get the codes, but couldn't find the screw to reset the ECU. I'm pretty sure that i broke it off in the process. I found out a couple of days later the guy iwas working with had an OBDII scanner, i just had him reset it.
eric99SE: that actually sounds better than all this turn screw here, turn screw there BS. how about some pics, or maybe if you're generous, a write-up?
Old Mar 11, 2003 | 02:20 PM
glimmer1's Avatar
Ok, I found the screw. Now I turned the ignition key to the second position as per the directions. Then I turned the screw in the ECU clockwise till stop waited 5 sec. then turned it back to original position.
I got nothing.. no blinking lights no sound ...nothing. I waited 5 minutes then tried again.
Still nothing.
The "Service engine soon" light is still on.
Old Mar 11, 2003 | 03:20 PM
fisher's Avatar
Still nothing.
Here are directions for getting codes:
http://vbxmaxima.8m.com/ecu.html
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Still nothing.
You should waite about 2 sec. and you have to turn the key to acc not on. before the car starts. then turn the screw clockwise.
Old Mar 11, 2003 | 03:30 PM
glimmer1's Avatar
Those are the directions I used... I didn't see any blinking
Old Mar 11, 2003 | 03:36 PM
CystumMax's Avatar
what do you feel wrong about your car? did you notice a problem with your car?
turn your car on let it run for 3 min, then turn it off. then repeat the methond on vbx site. waite for like 3 min let the ecu record data.
Old Mar 11, 2003 | 04:18 PM
fisher's Avatar
Is your engine light on while the car is running? If not, there are no troubleshooting codes.
If your engine light is on with car running and you are unable to obtain codes by turning the ecu screw, I would suggest taking the car to your local AutoZone. They'll hook up an OBDII scanner and get the codes for you, free of charge.
Old Mar 11, 2003 | 04:23 PM
CystumMax's Avatar
I didn't knwo autozone do that for free. good to know.
Old Jul 26, 2003 | 02:17 PM
HuliganRS's Avatar
Just did this on my car.
Reset the ECU with no problem!!!
I LOVE this forum!
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
