HELP! Clear Corner Problem
I recently installed clear corners on my 97 gxe. They look great, but I have a problem. The two pieces that just snap in are not holding very well. The left one actually came out, the right one hasn't but it's not as snug as I would like it to be. What can I do to fix this? I got them from custommaxima.com.
Can I get those little plastic things that they snap into somewhere and perhaps get something a bit smaller so they hold? What's my options. I know duct tape would fix it but that would look kinda bad :P
Originally posted by dss42
Since i have the sarrona body kit i had the same problem we put some kind of glue and tape on top over night it glued on and no problems now took the tape of next morning
Grrr, I wanted to avoid glue. Not sure what kind of glue would work good...I have some really good stuff but it eats plastic hehe. I suppose I will have to go pick up some epoxy.
Originally posted by 95emeraldgxe
get some washers and place them behind the bumper onto the bubs on teh larger piece of the clear corner, that will hold them in securely
Originally posted by OdiN1701
Only problem with that is getting them out again to change the light. Oh well, I suppose that light should last a very long time.
Don't glue it...take out the existing stud from the back of the lense and remove the white piece from the hole as well. Get a screw(forgot the size), but one that will fit into the hole that you took the stud out of. Also get a washer and screw it in from behind. I did this and I haven't had a problem w/it since. If it is hard to picture all this email me and I will take pics and email them to you...
this is why we need search function. im sure the answer is out there for him, plenty of times.
we cant even tell people to search anymore
put a bit of silicone or something in the nub socket and maybe itll hold tight
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
