Bad MPG .. Any Help??
Old Mar 11, 2003 | 04:55 PM
coryf's Avatar
96 maxima GLE (automatic), 79000 miles with 17s. im gettin anywhere from 14-18 mpg. thats whack right?? replaced spark plugs last week, new air filter, and cleaned the fuel injectors. regular driver, using the recommended 93 octane. any suggestions??
Old Mar 11, 2003 | 04:59 PM
TheMax95's Avatar
Re: Bad Gas Mileage...
knock senser?
Old Mar 11, 2003 | 09:07 PM
taggate's Avatar
try to get the gas filter change, clean throttle body, flush engine oil, flush tranny oil, and make sure the tire pressure is right. that is all i can think of.
Old Mar 11, 2003 | 09:17 PM
MacGyver265's Avatar
A big one is to check the tire pressure. I had one tire down to about 25 PSI one time and it was killing my mileage.
Old Mar 11, 2003 | 09:22 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
How would Gas filter cause the car to get less miles?
Old Mar 11, 2003 | 10:08 PM
Jr'sMaxima's Avatar
clogged fuel filters do cause a MPG lose.....I gained about 2 mpg back from it when I put a clean one in
Old Mar 12, 2003 | 01:04 AM
Bgohan's Avatar
Re: Bad MPG .. Any Help??
10 MPG is a big loss in mileage.
Look for a vaccuum leak, broken, or disconnected vacuum line.
Did you change PCV valve?
Have you checked your computer codes?? Just because the check engine light is not on, does not mean a code is not present due to a failed sensor. Car may be running in default mode.
Have you tried adding a good injector cleaner to the fuel tank?
How good are your battery and battery cables? If the voltage is low, or cable is loose, computer will keep resetting itself.
Is your odometer correct?
When all else fails,
Install a locking gas cap.
Old Mar 12, 2003 | 03:13 AM
looney662's Avatar
PCV valve? Knock Senser? Where can I find these parts cause my maxima is getting bad MPG too! I got a check engine light on for a "0803- Absolute Pressure Sensor." Anyone have an idea on what this is and how to fix it! Gas is getting as high as $2.30 for 91 here in Cali and i need to get this fixed asap!
Old Mar 12, 2003 | 10:01 AM
coryf's Avatar
all great ideas thanks
yea the gas filter was the last thing on my list, though a very important one. im having a diagnostic computer check tomorrow, to check the codes. odometer may be wrong, or even the gas gauge i thought. either way what a terrible time to be fillin my tank every 5 days. its ripped a holein my wallet so huge i cant pay for food.
IM DYING FELLAS
Old Mar 12, 2003 | 12:13 PM
Geophrum's Avatar
question i am getting not so good gas milage too and i have cleaned the throttle body changed the fuel filter, spark plugs, pcv valve, knock sensor. even have a locking gas cap the only htings i can thing i have left to replace are all 3 of my o2 sensors (wich i already bought...OUCH$$$$)
And still the gas mileage isnt what it used to be
Old Mar 12, 2003 | 12:40 PM
Jr'sMaxima's Avatar
Take the lead of your foot
Old Mar 12, 2003 | 04:48 PM
Geophrum's Avatar
Thats harder than replacing the knock sensor hahahahaha
Old Mar 17, 2003 | 02:20 AM
Bgohan's Avatar
No wonder.. You forgot to change the p an bu
Also, you should check the se n that go to th man . It might help you gain a few MPG back.
chisam14
Nov 6, 2018 08:56 PM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
