Got Nissan dealer front brake job quote, brake job question?
Old Mar 12, 2003 | 10:58 AM
maximaxgtr's Avatar
hey guys, i recently called my Nissan dealership for a price quote to change the front brake pads out only and they asked for $140 to do this, which includes the part.
My question is... is it necessary to "machine the rotors"? Cuz this guy quoted me $230 to machine the rotors and change the front brake pads and he made it sound like a huge deal to get them machined otherwise the "rotors will vibrate alot with the new pads and the rotors won't be grooved right to the new pads?".
I think my rotors are perfectly fine still, but do you guys think I should pay an extra $90 and do what this guy recommends? I'm not sure if this guy is just trying to rip me off some more by doing this. Any advice would be greatly appreciated. Thanks alot.
Old Mar 12, 2003 | 11:01 AM
PedalKick's Avatar
Re: Got Nissan dealer front brake job quote, brake job question?
If your brakes exhibit no vibration and the braking surface
is relatively smooth with no deep grooves, all you need are
new pads.
Old Mar 12, 2003 | 11:05 AM
amixam98's Avatar
Needs non-Maxima Friends
Buy the brakes on your own and have a shop install it for you.
Old Mar 12, 2003 | 11:26 AM
imstuckherenow's Avatar
or jus buy the pads and do the break job urself, its not all that hard
Old Mar 12, 2003 | 11:43 AM
Ramius83
It used to be a rule of thumb that you machine the rotors every other brake job. But, recently, every shop/dealer has been doing it everytime to get that extra 50 dollars or so lol......
I would just replace the pads if the rotors appear to be in great shape, both inside and outside surfaces......
Old Mar 12, 2003 | 11:44 AM
1MAX2NV's Avatar
You don't need to get them machined. The super shiny surface is better for braking than a freshly machine cut surface. The reason they want to machine them is to make money. What a better way to make one hour worth of labor just letting a brake lathe do everything while you sit around.
Old Mar 12, 2003 | 11:48 AM
Geophrum's Avatar
i replaced the rotors with brembo rotors and orderd the pads from curtesy nissan and the hard ware all for less than that
Old Mar 12, 2003 | 12:05 PM
1996blackmax's Avatar
If you want to have them replaced by a shop go somewhere else. I pay $140 dollars for the complete job, resurfacing included, at my local Nissan dealer. I thought I was paying too much, now I don't feel so bad.
Old Mar 12, 2003 | 12:57 PM
Nismo98's Avatar
Just bought a set of (4 Brembo Rotors & 4 Axxis pads). Total with shipping was a little over $ 300. Should have them in couple of days and labor is costing me $ 100. Pep Boys quoted me $ 500 with only new pads, 2 new front rotors, and resurfiesed the rear rotors. I asked them how much for the labor if I bring my own **** in, and $ 220 is what they told me. Plus all those parts were some bullsh!t brand. Does 1 bill sounds about right for the laber?
Andrei
Old Mar 12, 2003 | 02:19 PM
hell i got charged like 180 to get a set of front pads put on my max at firestone back in WV. everytime i went to that shop (which wasnt often) i always needed new pads on front or back. so they got bout 3 brake jobs outta me in 1 YEAR. aint that some ****?
Old Mar 12, 2003 | 02:26 PM
Nismo98's Avatar
That's crazy, I better not go back the second time.
Andrei
Old Mar 12, 2003 | 02:50 PM
karguy's Avatar
Andrei
I think Pep Boys offers 2 grades of Raybestos Pads on their brake jobs. Raybestos is a quality line! $100 is a fair price if caliper pins are cleaned, checked for wear and regreased.
Old Mar 12, 2003 | 02:58 PM
Nismo98's Avatar
How are Raybestos Pads compaire to Axxis Pads. Also what rotors do Pep Boys use?
Andrei
Old Mar 12, 2003 | 04:06 PM
karguy's Avatar
[QUOTE]Originally posted by Nismo98
[B]How are Raybestos Pads compaire to Axxis Pads. Also what rotors do Pep Boys use?
AXXIS is a high performance pad while the Raybestos Quiet Stop pad increases braking but not as much. QS pads are also quieter and dust less. Its a trade off, buy according to your needs! I have the QS on 2 cars so I am a little biased. I have had rotors turned at Pep Boys, cost $8 ea which is very fair. Don't know whose rotors they use, I bought Brembo rotor Group Deal when I did mine. $200 + $33 shipping.
Old Mar 12, 2003 | 04:24 PM
Nismo98's Avatar
That's not bad, I payed $ 280 + shiping for all 4 Brembo rotors and Axxis pads.
Andrei
Old Mar 12, 2003 | 07:28 PM
Bgohan's Avatar
""The super shiny surface is better for braking than a freshly machine cut surface. ""
Not true. Some mfg. specify a fairly rough machined surface face on their rotors. This allows for proper brake-in of metalic-type brake pads and prevents grabbing/binding and squeeling. A quality brake repair shop will know how to turn a rotor properly for every car. All they have to do is look it up.
If you check the runout of the rotor, and it is within factory spec, and does not have any deep grooves, you can remove the surface glaze by hand sanding rotor surface with 100 grit garnet paper. Theglaze, if not removed, may cause squeeling.
Turning rotors every time you replace pads, unless neccessary, is a waste of money not only for the turning, but the rotor will need to replaced much sooner.
Old Mar 12, 2003 | 08:29 PM
White96MaxSE's Avatar
I have NEVER had my rotors turned since I bought my car new and I have no warpage and no pull, and now I have 202,000 miles on the Max!
White96MaxSE
kirkhilles
Aug 8, 2015 10:53 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
BassAddictJ
Aug 4, 2015 11:38 AM
