New starter needed which one to get?
Old Mar 12, 2003 | 01:27 PM
lightboy's Avatar
I have a whining/grinding starter (with the fly wheel) and it needs to be replaced but from what I remeber there are 2 different brands or types for the 95 GXE but this is recalling from memory. Also I was wondering anything else I should know like best brand to get etc. etc. Justifying my post with no search feature I would greatly appreciate your help.
Old Mar 12, 2003 | 03:34 PM
Naujik's Avatar
I don't mind replacing or repairing my starter on my '96 as well.. that sound when starting the car is quite annoying.
Hmm, wasn't this on the FAQ? I will look again..
Old Mar 20, 2003 | 06:07 PM
maxxed out's Avatar
I recommend getting your starter from the dealership. I replaced the starter on my 96 last year. I bought one from Autozone at first, put it in and nothing happened. I pulled everything off and reinstalled it thinking I did something wrong but again nothing happened. I finally had to take it to a mechanic who told me some aftermarket starters for some nissans will not work and I would have to go with a Nissan starter. He put it in and the car cranked right up. My advice is to spend the extra cash up front and get a Nissan starter. The job itself is pretty simple.
Old Mar 20, 2003 | 06:21 PM
XXXL Cracker's Avatar
I got one from Autozone for $140 and installed it myself.....
Dealer will rape you while smiling at you....
D
Old Mar 20, 2003 | 07:25 PM
PedalKick's Avatar
Re: New starter needed which one to get?
So, with no search, it needs to be said again:
There is a VERY high probability that there is nothing mechanically wrong with your starter. That noise is a classic symptom of the grease in the starter having turned into a sticky mess. This causes the pinion gear to hang up on it's shaft and not immediately disengage from the flywheel ring gear when the engine begins to turn on it's own. This makes a bad noise. Another symptom of the grease thing is the starter pinion will not move at all and the starter won't crank.
My advise is to remove it from the car and take it apart before buying a new one. It may only need new grease. Mine did.
Old Mar 20, 2003 | 07:30 PM
conz35's Avatar
Re: Re: New starter needed which one to get?
What kind of Grease b/c mine does it and i wanna fix it on Saturday.
Old Mar 20, 2003 | 08:36 PM
95emeraldgxe's Avatar
get yourself a rebuilt starter from pepboys, they all come with warranties, no need to buy a new one for like 3X the price from dealer. if you dont know how to install it, take it to any mechanic, its a one hour job
Old Mar 20, 2003 | 08:41 PM
shadygrey's Avatar
<---------- Official no-search hater #1
Old Mar 2, 2006 | 02:30 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Dude, I have NO idea.
Old Mar 2, 2006 | 04:02 PM
WhiteMaxima9600's Avatar
Stay away from the stealership!!!!! :
Old Mar 3, 2006 | 05:34 PM
Mishmosh's Avatar
I recommend any rebuilt one with a lifetime warranty. There will be times in the future where you may have hard starting and will want to rule out the starter...nice to know you can swap it for another at any time. Prices are reasonable. I went with autozone myself.
Edit: don't forget to apply a ground cable while you are at it--it will avoid future problems...trust me.
http://forums.maxima.org/showthread.php?t=452286
Old Mar 5, 2006 | 09:09 PM
97green's Avatar
napa make good ones
Old Mar 5, 2006 | 09:17 PM
96blblstickmax's Avatar
i replaced mine myself, took me about 4 hours get it done hehe... pretty long time for such job, but i was newbie placing it, bought a rebuilt one with lifetime warranty from autozone, it's been pretty good about two years, dont know how long will it last?
vingodine
45
May 21, 2016 12:46 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Samedi
Aug 13, 2015 04:05 PM
