Changing PCV Valve
Old Mar 12, 2003 | 01:27 PM
joshrao's Avatar
Changing PCV Valve
How easy is it to change the PCV valve? I have a front STB, and it looks like a really pain to take out the valve with the STB in the way. Does anyone know some trick to take out the PCV valve? Thanks.
Joshua
Old Mar 12, 2003 | 01:38 PM
djshawnee's Avatar
Re: Changing PCV Valve
Joshua
there is no real "trick". If you have small enough hands and some needlenose pliers... you should be fine.
Old Mar 12, 2003 | 01:43 PM
Midknight MAXX's Avatar
I just did this Sunday. There is a bracket holding the metal tube that connects to the rubber hose on the valve. Remove the two 10mm bolts and it make easier. I hope this helps.
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
tardrex
Sep 11, 2015 07:35 PM
