Rear power window doesn't work. Howto needed.
Old Jan 13, 2001 | 12:54 PM
supertool
Hi. I just got a used 1996 maxima, and the rear power window doesn't work. I was just driving it today, and all of the sudden the rear window goes down. I tried to pull it up. I can hear the motor working, but the window just hangs there. I had to pull it up myself and tape it to keep it shut for now.
What could be the problem, and how can I fix it? Please explain in very easy terms, as I am not too automotively inclined.
Old Jan 13, 2001 | 02:40 PM
dch95's Avatar
Ghost in your machine
Does either switch work the window at all? If not it,s probably the power window regulator which is located in the door of the window that does not work. I,m unsure of what it looks like but it has a connector with 2 wires on it. If that regulator is good then you have either a short in the motor or in your switches.
Old Jan 13, 2001 | 03:31 PM
supertool
All the other windows work just fine. I can hear the window motor turning when I press the button. Both up and down. But it's as if it's disconnected from the window, because nothing happens. The window just hangs there and can be moved by pulling it up or pushing down.
Old Jan 13, 2001 | 04:48 PM
dch95's Avatar
In that case
It,s probably not on track or it,s broke which of course requires removing interior door trim to see what,s up. Sounds like it,s electrically sound though.
Old Jan 13, 2001 | 07:47 PM
supertool
Where can I get a complete book about the Maxima that tells how to do this stuff?
Old Jan 13, 2001 | 08:06 PM
dch95's Avatar
Auto Manual
Since in your first post you mention that you are not mechanically inclined I wouldn,t suggest getting the Factory Service Manual since it runs around 90 to 100 dollars and you may not get much use out of it. I understand the Haynes manual is a good one to get though and I think they go for about 15 dollars. It probably has that information in there plus alot of other things you would need to know.
Old Jan 13, 2001 | 08:50 PM
supertool
Thanks.
I think factory manual would be an overkill, since I am obviously not going to try and fix complicated problems myself.
I am going to a autoparts store and see if they have those Haynes manuals.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
kjm900r
Aug 5, 2015 07:14 AM
