Jap spec info?
Old Jan 13, 2001 | 06:13 PM
Maxstilln's Avatar
Anyone know about the power out put of the jap motors, both turbo and non-turbo. I thought of getting the turbo and running the SC on top of the turbo, don't know if I have the ca$h for it.
Jeremy
P.S. How do I post pics?
Old Jan 13, 2001 | 07:35 PM
theblue's Avatar
huh? running a turbo on top of an SC? are you talking out of you a$$ or will anybody back up you up and say this is possible?
Old Jan 13, 2001 | 07:48 PM
emax02's Avatar
What do you mean jap motors???
Are you talking about the Cefiro motor?
Or do want to know how much HP a Max engine would have with a SC and a Turbo? It all depends on what size pully you put on the SC and if you have a Auto or 5spd.Also I don' think you could do a SC and a Turbo at the same time,because you only have one intake manifold therefor air can only be rushed in by one sorce not 2 like SC and Turbo.If you put a SC on a 5spd max with say a 3.51 pully with all the other mods you could see as much as 300 HP at the crank.BTW maybe you could do a SC and Turbo at the same time because I know you can have a SC and Nitrous at the same time so maybe just maybe.
Old Jan 13, 2001 | 10:59 PM
xHypex's Avatar
I've read of cars that were both Supercharged and turboed, but then it all comes down to $$$. Everything is possible, even if your car doesn't end up being much like a max anymore
-hype
Old Jan 14, 2001 | 08:06 AM
MardiGrasMax's Avatar
He wants a low compression motor so he can run up the boost on the SC? right?
Old Jan 14, 2001 | 01:32 PM
2000MaximaSE's Avatar
maybe it is possible to run it like a supra or 300zx. Having one turbo run into the other larger one... Maybe you can have the SC running into the turbo to make it spool faster. I dont see the point though unless you have your engine built up like crazy because it can only take soo much boost.
Adam
Old Jan 16, 2001 | 06:55 AM
Trippy_D's Avatar
Jap specs
VQ30DE- 222hp
VQ30DET- 270hp
its possible to supercharge a turbocharged engine, but i'd rather do one of these options properly.
Old Jan 16, 2001 | 07:04 AM
Maxstilln's Avatar
Thanks for the info, where did you find the specs on the jap motor? The reason I ask is I wonder if it the ecu that helps the jap "e" version reach 220hp? I think I'll just locate a 95-96 motor with low miles and build it up and add the SC. As far as the turbo with an SC, from what I understand its set up similar to a twin turbo with the SC to help spool the turbo but I still I'm not sure how that would work with the intake manifold set up, but it was just a thought!
Old Jan 16, 2001 | 11:43 AM
Black VQ's Avatar
Not just the ecu...
It's prolly just the same changes they made to the 5th gen Max. They have the same hp rating(222) when normally aspirated.
Quickywd01
Sep 21, 2016 09:36 PM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
