17 inch tire size recommendation
Old Mar 16, 2003 | 08:38 AM
Aziantank88's Avatar
i have to get 4 new tires...im running 205/40/17s right now and they look too thin...i want some tires that are a bit thicker..what do you think?
Old Mar 16, 2003 | 09:26 AM
Nealoc187's Avatar
SLOW
205-40-17 is a civic size tire, the proper size is 235-45-17, MUCH larger than those rubber bands you are riding on right now.
Old Mar 16, 2003 | 09:59 AM
what about a 245/45/17 or a 235/50?
Old Mar 16, 2003 | 11:22 AM
ch13f's Avatar
What is the width of your wheels? 235/45/17 is the correct size for a 17x8 inch wheel. 235/50 would cause your speedometer to be off by a bit, and 245/45 is probably too wide unless you have a 8.5 inch wide wheel.
Old Mar 16, 2003 | 01:17 PM
DpG $h0rTeE's Avatar
I have a 17x7 inch rim. Will a 225/45/17 fit??? I have a 215/45 right now and want it to be a bit wider
Old Mar 16, 2003 | 01:44 PM
ejj's Avatar
ejj
Yes.
Old Mar 16, 2003 | 02:14 PM
Originally posted by ejj
Yes.
they may be 17 x 7 or 17 x 7.5? what size should i get then?
Old Mar 16, 2003 | 03:06 PM
ch13f's Avatar
225/45/17 in either case should be ok. 235 is too wide, especially if they are just 7 inches wide
Old Mar 16, 2003 | 03:43 PM
meccanoble's Avatar
Sports Button FTW
thats way too big, some would argue that 225/45/17 is better than 235/45/17 ( i have 225) but everyone agrees that 245 is too big...
Old Mar 16, 2003 | 05:15 PM
dwapenyi's Avatar
If you have 17x7, 225/45/17
If you have 17x7.5, 235/45/17
Use this tire size calculator to compare sizes;
http://www.miata.net/garage/tirecalc.html
245s would be going too far, unless your engine has a major power upgrade, like a turbo or SC or NOS.
DW
Old Mar 16, 2003 | 06:52 PM
m86stanggt's Avatar
Offset?
DW
What should the rim offset be for the max?
Old Mar 16, 2003 | 07:53 PM
MaximaPower's Avatar
i have 17x7 with 225/45...if i could do it over again i would go with 225/50
Old Mar 16, 2003 | 07:58 PM
Nealoc187's Avatar
SLOW
You can fit a 235-45 on a 17x7" wheel. It's not recommended by the manufacturers but it can be done without trouble.
Old Mar 16, 2003 | 08:06 PM
T2CTeamShift
What
What is the Stock Tire Size
Old Mar 16, 2003 | 08:10 PM
Re: What
i believe 5th gen stock 17s come with 225/50...correct me if i'm wrong
Old Mar 16, 2003 | 08:43 PM
ejj's Avatar
ejj
Can you put a 245 on a 7.5" wheel?
Old Mar 16, 2003 | 09:42 PM
TSW's Avatar
TSW
Yeah, you can put 225/45Z on your rims, BUT It’s pushing the limit of your tires. Especially with low profile like 45 and Z speed rating you are asking for a fast tire wear.
The best set up is 215/45Z for 17X7 rims or get 17X8 for 225/45Z and you will be really set for some nice performance.
P.S. Depending on the tire brand the 215/45Z than 225/45 might appear wider.
markevans999
Oct 25, 2015 08:27 AM
240tomax
Sep 13, 2015 03:28 PM
minsbang
Sep 11, 2015 08:48 PM
Maxboy23
Sep 4, 2015 06:04 PM
sdotcarter
Sep 2, 2015 09:53 PM
