help, grinding noise
Old Mar 17, 2003 | 05:22 AM
nick1020's Avatar
Every time I start my car it makes a grinding noise, something like if the car was already on and you tried to turn the key again, it's that kind of noise. I don't know if it's the starter but the car does start fine, except for the damn grinding noise. Does anyone have a clue to what it is? Thanks
Old Mar 17, 2003 | 05:32 AM
njmaxseltd's Avatar
Your starter needs to be regreased.
Go here - www.motorvate.ca and look under starter fix.
It's an easy job, good luck!
Old Mar 17, 2003 | 01:59 PM
nick1020's Avatar
I checked that site out and it was for the stater making a screeching noise not a grinding noise. It makes a metal on metal grinding noise like you are trying to start the car after it's already started.
Old Mar 17, 2003 | 02:21 PM
Maxima95Tuner
My mom's 96 max does that too. It's definately a starter problem, and Im going to check it out tonight, and Ill let you know what I come up with.
Old Mar 17, 2003 | 02:25 PM
optimus310's Avatar
just replace your started and it should fix the problem. My was doing the same but out of nowhere it stopped.
Old Mar 17, 2003 | 04:35 PM
Maxima95Tuner
I wouldnt replace the starter unless I had to. If worse comes to worse, Ill get her a new starter, but hopefully both me and nick1020 can fix our problems
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
