Help! Do I have any business removing the intake manifold collector?
Old Mar 17, 2003 | 12:41 PM
bhmax's Avatar
I think I saw a few months ago someone else did this absolutely genius mistake, but of course I forgot about it until I did it. I decided to clean the throttle body and possibly the IACV-AAC valve. I removed the intake with no problem. However, once I was actually in the cleaning process, the little red tube shot off the intake cleaner can and (I'm 90% sure) past the throttle body. OK, now that you've quit laughing, what do I do? I say 90% because it's theoretically possible that it shot off somewhere else in the engine bay, but I can't find it. I can't actually see it in the collector. I've removed the IACV-AAC valve to see if I could see better, but no.
Keep in mind that this is the most in depth thing I've done with my engine other than changing the oil. I haven't had any difficulty removing what I have so far, but is it easy to mess something up if I remove the intake collector to get the tube? Is it absolutely necessary to replace the collector gasket? Should I replace anything else while I'm at it? Thanks for the help.
Old Mar 17, 2003 | 01:52 PM
timmax's Avatar
Re: Help! Do I have any business removing the intake manifold collector?
Try a wad of duct tape on a coat hanger, but wrap it all the way up the hanger, sticky side out, so you don't lose it, too.
Old Mar 17, 2003 | 06:38 PM
bhmax's Avatar
Problem solved! Thanks a lot, timmax. Excellent idea. I was actually in the process of removing everything around the collector to remove it when I read your response. I had even gone to the dealer to get a new gasket for it. Although I couldn't get the tube with the hanger/duct tape, it got me looking into the hole for the IACV-AAC a lot harder. I was finally able to barely see it with the help of a mirror. My dad had some old orthoscopic surgery tools that he used to sell lying around. One was basically like needle-nosed pliers, but a foot and a half long. That did the trick, at least after trying for about 15 minutes. I was very glad to not have to remove everything, thanks a lot.
Old Mar 17, 2003 | 07:39 PM
Dave B's Avatar
Not DAVEB the parts guy
I say we chalk this experience up to the "**** happens" clause.
Glad you could solve the problem before having to resort to yanking the manifold.
Dave
Old Mar 17, 2003 | 08:19 PM
maxdis1's Avatar
With all the stuff happening (War and thing) , you have managed to make me laugh . Thank you sooo much . I am sorry, but I am glad you have solved your problem. Really thank you for making my evening.
Old Mar 17, 2003 | 08:42 PM
BEJAY1's Avatar
Conecarver
Re: Re: Help! Do I have any business removing the intake manifold collector?
Old Mar 17, 2003 | 09:11 PM
bhmax's Avatar
Glad to cause some laughs! Hopefully, though, not too often...
James92SE
142
Jan 2, 2024 09:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
Mahmuth
Sep 17, 2015 11:45 AM
