Dropping my car 2"
Dropping my car 2"
I am about to drop my car 2" from stock. I have 2 inch 5 spoke nissan rims and I don't really know how it's going to look. Can anyone show me pics of how this might look if they had it done on their car. I would like to see it because if I don't like it then I don't want to waste my money. Thanks again.
check out my page
www.cardomain.com/id/smackdown85
its lowered slightly under 2" and im completely satisfied..
hope it helps
hope it helps
Originally posted by SmackDown85
check out my page
hope it helps
check out my page
hope it helps
Re: Re: here you go
Originally posted by Maxima95Tuner
that is so pimp...
that is so pimp...
sup guys.. im still in market for a drop. for all those with the 2 inch drop with sprints.. i know the ride is a little rough.but how is the camber. is there a noticeable negative camber? do your tires wear really unevenly and faster. ?
I dont have a 2 inch drop on mine, but I know for a fact you should need the camber kit. They are only about 40 bucks, but it will save you so much money in tires in the long run. Im getting the Eibach 1.3 inch drop and I plan on getting the camber kit.
i have a 2 inch drop on sprintws/KYB's
and its not that bad ,really in coming from GLE sprints and i can truly say to me its about like the SE springs that are in my 3rd gen ,i also have buddys here with maxspeeds.progress,and h&rs to me it about the same ride except for bumps are a kind of harsh but how bad are the roads where you live? that the real question.
Well, I live in Chicago and the streets are not that good actually, at least the ones that I take most often. But other than that it's okay. I was wandering if it would ruin my tires and possibly anything else if I just replaced the springs. Cause I don't have that much money to spend. Unless someone wants to give me a bad *** deal
. Well, If anyone can help me out with this, I'd appreciate it. Thanks a lot.
Darek
. Well, If anyone can help me out with this, I'd appreciate it. Thanks a lot. Darek
Re: Re: Re: here you go
Re: Re: Re: Re: here you go
Originally posted by 4GRookie
Buss95Max and myself both have Sprints and neither of us have experienced any uneven wear at all. He's had his springs about 2 years and has put over 30,000 since and he has no complaints of uneven tire wear. Ive had mine for about a year with 20,000 have similar results.
Re: Re: Re: Re: Re: here you go
cool.no uneven wear..but does the camber look off..noticebly off with the sprints..
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
altome15
Aug 10, 2015 07:05 PM
