300 TT caliper SS line question
I got a good deal on some front calipers for my brake conversion, but no lines are included. Can I just buy some aftermarket SS lines for a 300 TT and will they will work on my maxima?
I wanted to know the same question so I went to the dealer. Supposedly, from 93 to 96, its the same for NA to TT. But from 91-92, it changed depending on the year and TT/NA. I would guess
that its the same basically because what company would do that to its people??
Hell, someone call NAPA and ask about the pad numbers- that might tell ya.
When ya find out- get back to me- cause I got a dime and I want my car to stop on it.
Scoob
that its the same basically because what company would do that to its people??Hell, someone call NAPA and ask about the pad numbers- that might tell ya.
Scoob
90 non turbo are 26mm alumninum
90 turbo are 30 mm aluminum
91 n/a and tt are 30mm aluminum
first part of 92 are 30mm aluminum (both tt and n/a)
later part of 92-96 are 30mm iron (both tt and n/a)
yes ss brake lines form a 300zx will work. you might not be able to put the line in it's bracket on the strut assembly.
Originally posted by Ramius83
WARNING, the fronts will work, but that backs will not. The back rubber hoses on the 300ZX are VERY short, and they will not fit on the Maxima. However, the fronts will fit perfectly.....I know....
i hope to do the z calipers this weekend.. we are gonna try do to the rears as well... gotta see if we can rig the e brake to work..
Originally posted by 96shogunmax
so why cant we just use front ss lines for the rear?
but you would have to buy 2 sets of brake line kits (most kits come 2 fronts and 2 rears)
or get some custom done..
you can..
you can..
Will the parking brake still work?
THERE LIES THE PROBLEM....
i will be working on it this weekend and let you know about the rear calipers..
we shall see grasshopper...
I was wondering because I found all 4 aluminum ones freshly remaned for like 300. I got to get 4 front ss lines if this works.
is your fronts calipers 28mm or 30mm?
bbsitum
Sep 11, 2015 04:55 PM
sdotcarter
Sep 2, 2015 09:53 PM
