lowering springs
Old Mar 19, 2003 | 01:39 PM
99SERMAX's Avatar
lowering springs
I own a '99 SEL 5 speed and want to drop the front end about an inch without dropping the rear...check out my web site and you'll see why
any help would be appreciated.
Old Mar 19, 2003 | 02:26 PM
Redmax's Avatar
Redlinemax Owner
Re: lowering springs
I checked ur site and i don't see why u want to lower the front and not the rear!!
Old Mar 19, 2003 | 03:21 PM
99SERMAX's Avatar
Re: Re: lowering springs
I like the height of the back but the front sits up to high and it will actually even out the front to the back
Old Mar 19, 2003 | 05:26 PM
spiff56747's Avatar
get H&R springs for the front
Old Mar 19, 2003 | 05:31 PM
maxfanfromohio's Avatar
Shiver me timbers.
You need to lower the whole car.
Old Mar 19, 2003 | 07:02 PM
drewm's Avatar
I'd recommend lowering the whole car instead of just one half of it. Most aftermarket springs are a stiffer spring rate than stock meaning that if you only replace the front springs with stiffer ones, you'll have a lot of problems with heavy understeer, similar to putting a heavy sway bar on the front of the car.
Also, most aftermarket springs for the maxima take the height into consideration and lower the front more than the rear, so which ever springs you choose, except for intrax, you will have a uniform drop.
Old Mar 19, 2003 | 07:15 PM
99SERMAX's Avatar
Thanks for the help..., I don't want it slammed, just 1" front and about .8" in the rear...the closest I've found is 1.4 (front) 1.0 rear.
any suggestions.
Thanks again
Old Mar 19, 2003 | 09:16 PM
DR0832's Avatar
question
why does it seem like a 2 inch drop r3ally isn't very much. I mean I have never seen it on a car, but say I have stock 15 inch tires, and then I go to some 18 or 19 inch tires. Doesn't that mean I am raising the car 3-4 inches, and then a 2 inch drop would only lower it to have of what the stock height was. Am I missing something? It seems like this is a waste of moeny. Isn't there anyway to lower the card like 4 inches so you see a significant different or is that not possible with 18s or 19s?
Old Mar 19, 2003 | 11:17 PM
spiff56747's Avatar
Re: question
just because you get bigger rims doesn't mean the overall wheel + tire diameter gets bigger. the idea is to keep the diameter the same so that your speedometer still reads right
Old Mar 20, 2003 | 04:32 AM
drewm's Avatar
any suggestions.
Thanks again
I personally have eibachs, which were probably those springs you are talking about, if you'd like to see a picture of them, I have a few on my homepage. http://www.bol.ucla.edu/~drewm/maxima/
A lot of people say they ride really rough, which might be true, but that's just my personal preference. If you aren't looking for a rough ride, the H+Rs ride a lot softer and are a lot easier on stock shocks. The difference in drop between H+Rs and eibachs is extremely slight, most people can't tell.
I'd say H+Rs for you, they are about 1.6 front and 1.2 rear.
Old Mar 20, 2003 | 05:29 AM
95Max's Avatar
Suspension Technigues springs will lower about 1.3"
Old Mar 20, 2003 | 05:52 AM
darrick's Avatar
Dallas Nissan Enthusiast
well my buddy(bluebob)
has maxspeeds and 2 me this is the lightest drop you can get checkem out
Old Mar 20, 2003 | 07:34 AM
DR0832's Avatar
any others
I see. Thanks for clearing that up. I definitely don't want a rough ride. I don't know why anyone would want that. How are sprint and maxspeed sprints. I am trying to get the best ride I possible can. I have heard to use a maxspeed spring/AGX GR2 Strut combo to get a really nice and smooth ride. Anyone have any insight on this?
Old Mar 20, 2003 | 08:16 AM
2KxSEx's Avatar
The maxspeed+any kyb struts will have you saying "I never knew this road was THAT bad" if you live anywhere where the roads aren't perfect.
Peace.
Old Mar 20, 2003 | 03:03 PM
DR0832's Avatar
damn
there goes that idea. well whats a better combo then to get a nice smooth ride?
Old Mar 20, 2003 | 03:17 PM
ch13f's Avatar
If you get adjustable struts and keep them on the softest setting I don't think any springs will be unbareable. Probably stay away from Eibach, Sprints and Intrax though.. Eibach is really stiff, Sprints are really low and pretty stiff, and Intrax are low and stiff, plus the rear rides a bit lower than the front.
Old Mar 20, 2003 | 03:30 PM
99SERMAX's Avatar
I like the idea of the h+r,s 1.6 & 1.4. do I need a camber kit for the front and back or just the front.
Thanks for the help
Old Mar 20, 2003 | 03:42 PM
2KxSEx's Avatar
Tokico blue struts+H&R springs. Smoothest ride w/ a nice drop. No camber kit needed in the front. The back tires can't be adjusted for anything anyway.
Old Mar 20, 2003 | 05:27 PM
infinit30t's Avatar
Also check out Progress springs, The right amount of drop and a ride like H&R, plus they are progressive unlike the maxspeeds
Old Mar 20, 2003 | 08:25 PM
drewm's Avatar
Thanks for the help
I don't have a camber kit, and my tires wear perfectly evenly, I'd say nope.
Old Mar 20, 2003 | 08:49 PM
drewm's Avatar
Re: damn
The stiffer the ride, the less your car will lean in a corner and (generally) the faster you can take a corner. Depending on a lot of other factors too.
I personally think maxima eibachs aren't very stiff at all. I've been in a Supra with H+R Race springs, and an eclipse with JIC coilovers and road race springs swapped in. Eibachs are soft.
Softest combo would probably be H+R + Tokico, or H+R + AGX, but they won't handle as well as an eibach + koni setup. It all depends on what YOU want out of your car.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
