Broken Horn
Old Jan 14, 2001 | 03:51 PM
Max96LSU's Avatar
Does anybody know how to fix a broken horn? Actually, the horn on the left (looking at the engine) works but the other one doesn't. I checked the fuses but thats not the problem, anyone have any info to give? Thanks in advance.
Old Jan 14, 2001 | 04:54 PM
Confused's Avatar
Permanent Maxima.org Resident
Did you check the connection on the horn?
you might want to unsrew the working horn and plug it into the non-working one... at least you will know if it's the horn or the electric.
Old Jan 14, 2001 | 08:49 PM
Max96LSU's Avatar
Re: Did you check the connection on the horn?
I was checking out your webpage, VERY Nice...I like where you mounted your Hella horns, I put mine underneath the left headlight.but its not working....did you use the relay that came with horns? I installed mine like MegaMAX (http://integra.vtec.net/geeser/megamax/horns.html), but i think I'm going to move it to where you put yours. Any suggestions would be great...thanks
Old Jan 14, 2001 | 09:39 PM
Confused's Avatar
Re: Re: Did you check the connection on the horn?
Just follow Megamax's directions for the wiring and be prepared to make several trips to the hardware store,,lol..
Old Jan 14, 2001 | 09:57 PM
Max96LSU's Avatar
Re: Re: Re: Did you check the connection on the horn?
Cool....thanks.....by the way, did you use the relay or not on your car?
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
