Need Advice: Taking tint off back glass with rear defrost
Old Mar 19, 2003 | 08:37 PM
Zeks 97SE's Avatar
HEy, im taking the tint off the back glass of my car and I have a rear defrost. Any suggestions? Im thinking this is going to put and end to my defrost but hey im not a window tinter or remover .. any pros out there ?
Old Mar 19, 2003 | 08:58 PM
1MAX2NV's Avatar
Re: Need Advice: Taking tint off back glass with rear defrost
Take it to the pro. They have a special technique and the right chemical solvent for the job. It's not worh saving the $50.
Old Mar 19, 2003 | 11:22 PM
carnal_c30's Avatar
Former Sponsor
Re: Re: Need Advice: Taking tint off back glass with rear defrost
yup and wait for a sunny day too and leave your car out in the sun a few hours before the shop works on your car, it makes it easier to take off and alll the time you 'waste' will be nothing compared to the time it will take to redo your defroster lines
even if you take it to a shop, they wont always be able to do it without taking your defroster lines off
good luck!
Old Mar 20, 2003 | 12:36 AM
bayside206's Avatar
I did it last week . I used heat gun (hair dryer should work also) to
heat the corner and pull the sheet slowly while heating more area the same time. Glue from the sheet still left behind. I used acetone(nailpolish remover is ok) to remove glue . The rear defrost wire is
still intact . It taked a few hours to do it.
Steve
Bayside ,NY
Old Mar 20, 2003 | 08:09 PM
SamMan23's Avatar
A tint man told me this. Do this at your own risk. Take a trash bag and cut it to fit the window. spray the inside of the window down with 409 and put the trash bag so it sticks to it. LEave it in the sun. Try to take off the paper. If the tint's too old it won't work. Good luck.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
altome15
Aug 10, 2015 07:05 PM
