No power until 3k
Old Mar 20, 2003 | 10:20 PM
EGRIZWALD's Avatar
No power until 3k
I have noticed latley that my 98 SE auto has very little power from idle to around 3k rpm, after 3k it pulls hard. Just gave it a tune-up last month and adj. the throttle cable. Only code I have is for rear o2. It only started to bother me when I was on a trip a couple of months ago with a rented 02' ford tauras V6 automatic that I swear would eat my maxima for lunch only because of the off-the-line performance. Any ideas? This is starting to drive me nuts.
Old Mar 21, 2003 | 06:05 AM
njmaxseltd's Avatar
From 3K on your Maxima will eat the Taurus.
Clean your throttle body - www.motorvate.ca that gives back some throttle response.
I don't think the rear o2 will effect performance.
What kind of plugs did you use when you tuned it up?
You could have a defective or over active knock sensor which is holding back your ignition timing.
Old Mar 23, 2003 | 01:16 AM
chris j vurnis's Avatar
I had very similar symptoms until I changed the knock sensor. There was an immediate partial improvement and then more improvement in the low end over a few tanks of gas.
Old Mar 23, 2003 | 08:23 AM
bhmax's Avatar
Chris, did you get the computer code for the knock sensor or anything else?
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
