full exhaust cost, quality, performance?!?
Mar 21, 2003 | 11:18 AM
I am gettin rid of my 95 auto max for a 97-99 5 spd. Haven't found one yet, but will not settle for anything else. On my 95 I tried to make it look like a ghetto whoopdy ride. I want the new one to be built performance wise. All I had on my 95 for exhaust was a muffler.... I wish I could search for all this, but what are your opinions on full exhaust, I am looking for best performance on a reasonable budget. Any do's or don'ts?!? What are the website for performance stuff for the max's?!? Thanks for your help...
Jason
Mar 21, 2003 | 11:49 AM
Exhaust on a resonable budget?...just get y-pipe, leave everything else stock, u wont miss much (except looks/sound)......unless u r planing to boost later
Mar 21, 2003 | 11:58 AM
Quote:
....sooooo a catback does nothing, and eliminating the cats doesn't improve anything?!?! What would I lose by doing just a y-pipe, versus a FULL head back?? 2-3hp?!? or a lot.... I want to build this one for the track...
Money isn't really a major issue, I just don't want to spend $500 on something when a different company made the SAME THING for $300... catch my flow?
J
Mar 21, 2003 | 12:37 PM
budget or warpspeed y pipe, and OBX cat-back, together should run you less than $500
Mar 21, 2003 | 12:51 PM
Or, get a Y pipe from warpspeed, as well as the B-pipe with resonator, that way you get a $25 discount for getting both from them, and get a Mangnaflow Muffler. Thats what I have in mind doing since I already have they Y-pipe from them. Should look, feel and sound sweet....
Mar 21, 2003 | 12:56 PM
So the only beneficial exhaust components are the Y-pipe and b-pipe and a catback.... That will open her up good enough for some hp.... Is there bungs for the O2 sensors on the pipes??
Jason
Mar 21, 2003 | 01:52 PM
Quote:
Jason
The B-pipe is from the cat to the rear axle, meaning that it basically is a cat back minus approx. a foot of pipe and the muffler. I believe in all actuality that with a Y-pipe and custom 2.5 piping and resonator(reduces noise) from your local muffler shop and a muffler of your choosing would be the best bang for the buck. I don't think b-pipes produce any significant gains.
Mar 21, 2003 | 02:47 PM
budget y-pipe and greddy catback.
if you are short on money: budget y-pipe and OBX exhaust. obx is about $200 cheaper
Mar 21, 2003 | 03:14 PM
i still say that adding a catback wouldn't make that much difference in NA car......I think the loss by not putting catback should be <5hp
Mar 21, 2003 | 06:13 PM
my setup: budget ypipe, warpspeed metallic hi-flow cat, obx catback. Nice and quiet. Cost total under $500
Mar 25, 2003 | 11:48 AM
Where do I get OBX from?!?!
Are the O2 sensors on the Y pipe only, or is there one behind the Y pipe??
Thanks guys
Jason
Mar 25, 2003 | 02:41 PM
Re: full exhaust cost, quality, performance?!?
Jason
warpspeed Aluminzed mandrel bent y pipe
warpspeed b pipe with resonator
magnaflow street series 5x8 exhaust
note*maybe check on magnaflows racing series mufflers..
those three items will run you 525 and thats top end exhaust for a moderate price ...find a good ole joe that knows what he is doing to put it on, it cost me 80 dollars .. make sure you go back once a week, to get everything tightened up .. well thats my two cents, take your time, do some homework ..and enjoy what ever you get, goodluck finding a chariot
Mar 26, 2003 | 01:04 PM
By installing a y-pipe that it will remove the pre-cat, does it increases more air pollution and does it require some tweaks to pass the exhaust emission inspection?
Mar 26, 2003 | 01:28 PM
Quote:
Once you get your cat heated up, you'll have no problem passing inspection. The car only pollutes when it is cold. Make sure you drive the car for a good distance before you go in for a inspection.
Mar 26, 2003 | 03:22 PM
Right now the only performance mods i have are a stillen intake and a budget b pipe with resonator. i had the intake on for a while before i got the b pipe. the b pipe alone doesnt add a huge hp gain, im guessing 5-10. but you can feel an inprovement in the mid to hight rpm range. it also lowers the exhaust note a bit. if you look at the stock b pipe there are some serious crimps in it restricting flow. if you are going to do the exhaust, be consistant and do the y, b and muffler for the full set up. i plan on installing my budget y and borla muffler in the next few weeks.
go with budget, they are a good company, you have to call to place your order. they seem a little disorganized, they screwed up my order but were really nice and fixed it and gave me a nice discount for the mistake. thier stuff is stainless steel unlike warpspeed. i wouldnt put any aluminized pipes on my car.
