tranny cooler
i dont think there is a "best" one, get the biggest you can afford ( paid a relatively cheap $50), i had one for my previous car (probe GT) which was pretty huge, about a foot high. Needed that size since i was spraying and used an IAT mod (makes the tranny shift harder), lots of heat for the tranny, i guess thats similar to the VB for the maxs??
eric
eric
Originally posted by davey6693
I have a Hayden 404 which I think is recommended in general for Don's VB mod. It's certainly done a good job so far.
Originally posted by Jime
I don't want to badmouth Hayden but the B&M is more solidly built and has a cold temp bypass and for approx the same amount of money its the best buy.
D
Originally posted by JC96max
If you get the VB mod, you have to get a transmission cooler too?
eric
I think tranny cooling would be helpfull for those who live in a hot enviroment, like CA or FL. for those who are in NY, is it really worth it? with the cold weather in winter time. could the tranny get dammaged if it is really cold in winter time. becuause it would take long time for it to worm up????
I just installed a B&M 0255 this weekend. The stacked aluminum design is much more rugged and will resist damage from road debris better than the Hayden fin design. The B&M Supercoolers have a bypass for cooler weather as stated earlier. I've installed both, but like the way I could run the ATF lines straight downward on both sides of the center support with the B&M Supercooler. I ran them under the edge the center support with some 3/4" heater hose around them to protect them from wear. I put the under covers back in place exactly as they were. The Hayden is typically mounted horizontal so that both ATF lines are on one side so the hoses are routed differently. No big deal though, they both work. Took about a 1.5 hours to complete.
Originally posted by Redmax
I had my vb modified by a company here in MD on Friday. Therefore I needed a tranny cooler quick. I bought a Hayden 404. I installed it Vertically So far it seems like its working great. The tranny seems to be working Smoother as well. Is there anything wrong with installing it vertically?
Is the VB mod from maryland going do the same thing as the one from Max Tuning in NYC? I know that sounds like a stupid question but I heard that Aamaco does a VB modification but only extends the life of the tranny rather than give quicker shifting speeds.
This onne actually seems better than maxx tunning!
Re: Where to Buy?
Originally posted by T2CTeamShift
Does any one knoe where to buy a Tranny Cooler from, The generally range from 45-65 dollars right? I need one, I drive my Auto Agressivley.
i have the b&m w/my vb, i like the bypass valve.
corey--i thought that you had a 5-sp, do you have to worry about a tranny cooler or is it just for show?
Originally posted by djshawnee
would a transmission cooler help a 5 speed without any tranny modifications?
You five speed guys don't have to worry about that as you create the shift when you want it to happen
d
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
