HELP! Rear Brakes!
Old Mar 22, 2003 | 07:51 PM
cardio175's Avatar
HELP! Rear Brakes!
I'm in desperate need of help. My car is in my back yard with no rear brakes. OK... so I didn't think that they would be difficult to do. I replaced the fronts without any problem. I can't seem to get the piston to retract back into the caliper. If anyone knows what to do, please respond! I'm not at my computer so, you can not IM me. if possible call me 732 735 7722.
Old Mar 22, 2003 | 08:25 PM
cardio175's Avatar
anyone?
Old Mar 22, 2003 | 08:52 PM
nismomaxse97's Avatar
Originally posted by cardio175
anyone?
You need a piston tool that goes on a drive socket. Just go to any auto parts retailer and they should have one. the brake piston in the rear has to be turned into the caliper, you can not just push it back like the front. If you inspect the piston you should see 4 notches on the perimeter of the piston. The tool is basically a square with 4 prongs that fit in the notches of the piston. You might be able to get by without the tool but it is so much easier with it.
Old Mar 22, 2003 | 09:57 PM
cardio175's Avatar
Thank you all for all your support! This truly was a great experience!!! I used long nose pliers and tomorrow in the am I will bleed the system.
Old Mar 22, 2003 | 11:40 PM
Ramius83
If all you did was change the pads, then you do not have to bleed the brakes. You will be perfectly fine......
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
