Upstream o2 Sensor
Old Mar 24, 2003 | 08:13 AM
T2CTeamShift
Upstream o2 Sensor
Does any body know where the upstream o2 sensor is???
Old Mar 24, 2003 | 09:04 AM
T2CTeamShift
Common
Help me out guys
Old Mar 24, 2003 | 09:09 PM
rhammers's Avatar
Re: Common
Just had my CEL come on today with the 0303 code too. I believe it is down on the muffler but the electrical connector is in your engine. Would suggest buying a haynes to show exactly where it is and how to change.
Originally posted by T2CTeamShift
Help me out guys
Old Mar 25, 2003 | 12:00 AM
WizzaMax's Avatar
Upstream O2 sensors are off the front (left) and rear (right) banks of the engine UPSTREAM of the main catalytic converter.
if you look at the underside of the car or in a tune-up guide, you will see, the y-pipe coming off the front and rear into the exhaust.
the front O2 sensor is just around the stock heat shield and plugs into the harness in front of the NISSAN spark plug cover in your engine bay.
the rear or right side upstream O2 sensor is hard to see unless you are under the center of the car but is in the similar position on the pipe leading straingt into the bank bank of the manifold.
FYI, the downstream O2 sensor is on or just past the actual Catalytic converter prior to the long resonator before the rear suspension.
Just imagine this having another piece pointing up the same height as the middle pipe on the far left part of the picture and the O2 sensors bolt in there about halfway down each up-pipe.
Two upstreams normally for 4th gens...more possible for 5th IIRC adn downstream is to the right past the CAT on the picture.
Old Mar 25, 2003 | 01:56 AM
T2CTeamShift
Whoa
I Got the Code 0509, Like 3 people told me its my Upstream o2 Sensor from the forums before, they told me they got the info from the Haynes Manual, This is the reason I have a rouph idle right??? I also need new spark plugs and soooon, my car is Misfiring So BAD, it sounds like a V8 on crack or something cause I have a home made intake, like all my pulling ablitiys are gone, I have no more power left in her, untill I get new sparks!!! Any one know where to get cheap ones from around Chicago, Pepboys said they only have NGK Platiniums for my car, but they are like 15 a pop,
Old Mar 25, 2003 | 06:54 AM
T2CTeamShift
Any body?
Old Mar 25, 2003 | 06:21 PM
T2CTeamShift
HELP ME
HELP ME PLEASE
Old Mar 25, 2003 | 06:26 PM
WizzaMax's Avatar
you could have bought a new oxygen sensor from Jerry Rome Nissan and the regular NGK coppers and had them installed and running fine and dandy in the time you are waiting for more info on this.
Old Mar 25, 2003 | 06:39 PM
T2CTeamShift
Wait
The Stealership, How much would this all cost? Estimation will be nice
Old Mar 25, 2003 | 06:57 PM
WizzaMax's Avatar
Just contact Ken Athas at Jerry Rome Nissan www.jerryromenissan.com and talk to him about a quote for Maxima.ORG parts
he definetly has taken care of me and beat many other dealerships between 25%-50% in price shipped to me.
Old Mar 25, 2003 | 07:46 PM
T2CTeamShift
Thanx much
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
