how do i adjust rear koni?
Old Jan 15, 2001 | 04:15 PM
max1ma97se's Avatar
ok my koni struts finally came and i cant figure out how to adjust the back ones the instuctions sucks a$$ one has big complicating words my little head cant figure out then has these drawing to simple for me to make sense of errrr. any help would be apricated
Old Jan 15, 2001 | 04:55 PM
SUR4MAX's Avatar
Adjusting Koni rear struts
The ones I have, you have to compress the strut all the way...ALL THE WAY. Then turn left or right to firm up or soften. I forget if " + " is for firm or for soft. The symbols are stamped into the strut housing, a " + " and " - " I believe the " + " is to firm it up. Look at the pictures. I recall one of them showing which is which.
The crappy thing about the rear setup...is that if you want to adjust again, you have to take the struts off the car to re-adjust
Hope that helps.
Old Jan 15, 2001 | 06:59 PM
max1ma97se's Avatar
how do i compress the strut all tha way ???
Old Jan 15, 2001 | 07:34 PM
SUR4MAX's Avatar
Re: ?
Turned the strut upside down, and push down to push the rod into the strut. You have to push it all the way down, then maintaining the downward pressure to keep the struts compressed, turn the strut housing.
The instructions mentioned something about hearing clicks for each 360 degree turn, but I didn't hear any. Supposedly each click represent 1 complete turn.
I just kept track of the number of turns. The number of turns will depend on how stiff/soft you want your ride to be.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
bbsitum
Sep 11, 2015 04:55 PM
