Personal Review: BOMz Racing Cold Air Inakte + K&N Filter (eBay)
Old Mar 26, 2003 | 12:12 AM
happyricefob's Avatar
V^___^V
UPDATED!!! Personal Review: BOMz Racing Cold Air Inakte + K&N Filter (eBay)
[pix updated: 4-13:2003]
so i finally got my digital camera and i took couple pix of the intake and an additional mpeg clip. enjoy =)
**i added an extra hose to protect the pipe, jus in case it bounce around too much**
intake clip >> http://www.angelfire.com/zine2/happyricefob/bomzcai.MPG
[Installation]
My friend and I installed the CAI over the weekend without any instructions. Nissan made the stock intake system with a bunch of various rams and holes etc, but taking the stock intake system out was cake! (10 minutes job) The process of cutting the stock metal frame took us a while because we didn't want to damage any unecessary stock parts. After our articulous work (sort of), we realized there was already a big space provided just for the K&N filter to sit in. Lastly, we connected the PCV valves and intake arm with the provided hoses, jack up the car, and pop the K&N filter from underdeath. It was a 1 hour job with some music and chatter.
[Performance]
The rpm shifts A LOT more smoother than stock, or even my previous popcharger setup. I feel a decent gain from 2,500 rpm - 5,500 rpm in every gear (especially 2nd). Also the engine felt it wants to be pushed. The hoses were very tight so there's no extra air will leak from the intake pipe. The provided K&N filter is a bit small but aggressively aborbing every cold air as possible.
[Sound]
BOMz CAI sounds more like "blaaaaaheeeeeaaaah!" and popcharger sounds more "broooommmmm!"
I can also hear "shh....shh,.." sound from the CAI, it's a very neat sound =) and at WOT it sounds hella loud!
[Vision]
Since I polished my engine black and blue, the blue hoses and silver intake pipe matches with my engine bay really well. And it looks more spacious compare to the stock air system.
[Conclusion]
This product defintely is worth $80. It is made out of metal but not some cheap plastic piping. The K&N filter was pre-oiled and everything is ready to go. I feel the gains in performance as well as the sound I expect to hear from the CAI system. Overall it's a great product, worth every penny!
Old Mar 26, 2003 | 09:24 AM
V^___^V
i guess i wrote a bit long on this thread. hopefully the search feature will be back up soon so whoever needs opinion on eBay CAI they can view this thread as refernce.
Old Mar 26, 2003 | 04:25 PM
n2oMike's Avatar
One larger K&N filter that fit the 3" pipe on these ebay (Bomz) intakes is part number...
RE-0930
It has a 6" diameter base (end with the hole), it's 6" long, and the other end is 4-5/8" in diameter.
It is in stock, and available from Summit for $38.69 1-800-230-3030
There is also a pre-cleaner available for this filter. This is a 'sock' that fits over the filter to catch the bigger stuff. It has elastic to hold it in place. It is part #22-8033PK but Summit does not sell it... as it's listed as a 'motorcycle' part.
I'll probably end up purchasing one of the cheapies that comes with the small, generic filter, then buy this filter from Summit.
Here is a listing of conical K&N filters, and their measurments. http://www.knfilters.com/universal/univrndtap.htm
Good Luck!
Old Mar 27, 2003 | 12:22 AM
V^___^V
RE-0930
Good Luck!
thx ur info on enlarged K&N filter.
Old Mar 27, 2003 | 04:00 AM
stephenlc's Avatar
I want to get one of these, was finding the place to cut in the fenderwell hard and was cutting hard? What did you use to cut through it and are you scared it is going to rust? Haha, so many questions.
Old Mar 27, 2003 | 05:15 PM
V^___^V
i borrowed a big chainsaw tat SPECIFICALLY cuts metal, i had a driller to to drill some holes to start off, then stick the big chinsaw and cut a square... althought cheston suggested a circle shape, i cut a big sqaure without harming any important stock parts, stick the midepipe down, add an extra hose to protect the midpipe just in case it makes contact with the hole i drilled... then add the K&N filter from the bottom =)
Old Mar 27, 2003 | 05:17 PM
V^___^V
o yea... i hella pee my pants when my friend was drillin
Old Apr 1, 2003 | 08:29 AM
nismos14's Avatar
§è~® f®ÈÄk
anyway this can be mounted like the injen? not requiring cutting?
Old Apr 1, 2003 | 02:53 PM
V^___^V
nope, this one is like place racing... u gotta cut it =(
Old Apr 13, 2003 | 05:05 PM
V^___^V
just bumpin this thread back up.
Old Apr 13, 2003 | 05:17 PM
waveridr85's Avatar
i get mine at my door tommorow, how did you do the cutting? what tool did u use, where do you cut?
Old Apr 13, 2003 | 05:36 PM
V^___^V
big fat metal cutter and trim a big square WITHOUT damagin the stock frame. i jus cut below the fuse box, and cut it big enough for the piping to go thru, then jack up the car and stick the K&N filter in.
Old Apr 13, 2003 | 05:40 PM
Ceasars Chariot's Avatar
Old Maxima Legend
nice
hey love the post ! pics are cool and the clip was really awesome, i tripped out on your temp gauge ..ouch..bet you could fry an egg somewhere around there ... it was nice to hear the cai, it sounded very tame compared to my jwt pop ... do you have any clips of any runs down the road ... i would like to hear some .. post a link to any web pages you have also with any clips i would like to check them out ...great mod though , hows the power ?
Old Apr 13, 2003 | 05:42 PM
gtr_rider's Avatar
192.168.1.1
What is up with your Temp Gauge?
Old Apr 13, 2003 | 05:43 PM
waveridr85's Avatar
wat up w/ the temp guage?
Old Apr 13, 2003 | 05:45 PM
Smithdogg1's Avatar
Must be broken Sounds pretty good. Do you have anything else done to your car?
Old Apr 13, 2003 | 05:53 PM
n2oMike's Avatar
Here are some directions on how to install the Price Racing unit... which is pretty much the same thing as the Bomz. However, the Bomz does not come with the template used here. But, it's probably not really needed, as the piping can be installed first, and the location of the hole can then be 'eyeballed'. note... The page below is NOT mine. The fellow at the site gets the credit.
http://www.brian1.net/maxima/gen4_ca..._gen4_rev2.htm
I purchased mine from ebay, and it looks just like this one. It seems like a nice setup with powder coated 3" aluminum tubing. It's only drawbacks are the plastic MAF adapter and generic filter... but the piping is worth the $50. Hey, if you don't want to use the cold air part, it can be left off and you'll have a hybrid intake. The metal sleeves for the connectors are cool too.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33621
I made my own MAF adapter out of a piece of 3/16" steel and a short piece of 3" exhaust tubing using a welder, grinder and drill. I also plan to purchase a K&N filter #RE-0930 that measures 6" wide at the mounting flange, is 6" long, and is 4-5/8" in diameter at the end. I'll also be using a pre-cleaner to shield the filter from road debris and keep the bigger stuff out of it. It's part #22-8033PK
The filter costs $39.26 and the pre-cleaner is $15.99 at http://www.4filters.com They charge only $5 shipping on any order.
Good Luck!
Old Apr 14, 2003 | 09:04 AM
95seMax's Avatar
with a 4-5/8" opening on the end , will it fit all CAI , i taught the opening on the end was 3" on CAI , and i taught the part # was re280
i recently bought a k @n filter part # ru 3570 and it didnt fit over the end, it seemed too small or tight
i was just about to try again and buy another filter the re280 but which part # is the right one , will either one fit or is the re 0930 the right one
Old Apr 14, 2003 | 11:41 AM
n2oMike's Avatar
The RE-0930 has a 3" hole in the mounting flange for the 3" CAI tubing. The diameter of the FILTER at the flange is 6", and it's 4-5/8" on the other end. The filter's length is 6".
Old Apr 14, 2003 | 05:47 PM
V^___^V
sorrie guys... when i installed my euro reversed i didn't press the temp gauge face all the way down, and i'm jus too lazy to take it out again and fixing it =/
Old Apr 14, 2003 | 05:48 PM
gtr_rider's Avatar
192.168.1.1
Sender here..
http://www.vqpower.com/v2/modules.php?name=Reviews
Old Apr 14, 2003 | 06:35 PM
V^___^V
Sender here..
done please review!
Old Apr 15, 2003 | 10:34 AM
2KxSEx's Avatar
If you're intalling this CAI in a 99 cali spec you'll have a vacuum canister that's in the way of the lower intake pipe. You'll have to relocate the canister as I had to do no biggy. And that plastic adaptor is kinda weak but you can't expect too much for $85 right? Otherwise it's a very nice product that does it's job well. The car is SOOOOOOOOO loud outside it's not even funny. I can hear my car two blocks down the road!
Peace.
Old Apr 15, 2003 | 02:43 PM
V^___^V
Peace.
yea... the K&N filter was a bit small =/ i really wanna dyno this CAI then change the filter to either JWT or stillen and see the difference in performance =) but it's all good for rite now...
btw my review is approved by gtr_rider on vqpower.com... it's pretty much the same thing but here is the link for those who are lookin for opinions on this product in the future >> http://www.vqpower.com/v2/modules.ph...owcontent&id=6
Old Apr 15, 2003 | 02:46 PM
gtr_rider's Avatar
192.168.1.1
122 Hits already, wow!
97_GXE
20
Sep 17, 2015 08:12 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
