Problem with AC please help
Old Mar 26, 2003 | 05:14 PM
AuToMaX_95's Avatar
Recently my AC doesn't work. I check all the fueses and they seems fine. Just now i purchase the AC rechargeable kit from pepboys, i follow every signle direction and at the end my AC still doesn't work (btw heater works fine just AC).
Does any one have the same problem before?I just want to know how you guys solve the prolem.
please helpppp!
Old Mar 26, 2003 | 05:28 PM
† ErV †
some things:
if the gas pressure isn't right the compressor won't start
if the gas is of the wrong type it will also cause problems.
if the compressor clutch is broke it wont engage the compressor
it could be one of 10s of other things.
you really want to bring it to a good AC place and perhaps an electrician.
your heater will work because its a different system.
i changed the compressor.
Old Mar 26, 2003 | 05:48 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Re: Problem with AC please help
please helpppp!
AC is complicated, you will need to look at each component of your ac system to check for leaks. If you recharged it correctly and there are no leaks, the piping should be cold (ie, the tubing from the condenser outlet to the evap. To check for leaks, typically a shop will run a diagnostic by using a type of dye (visible to black light) in the freon when they recharge your ac. Then they run the AC and use the black light to check for yellow spots (where leaks may be occuring).
You may have problems with the following components:
Condenser (fins may be damaged, dented or clogged)
Evaporator (may be clogged)
Hose fittings (may be worn, cracking or developing bubbles)
Tap valve (look like a valve stem) by the left hand side charging pipe.
Compressor
Receiver/drier
I went through this ordeal last summer.. turned out I had leaking condenser and bad tap valve. I also had my receiver drier replaced too. Good luck.
AnGe
Old Mar 26, 2003 | 05:49 PM
ZeRo MaX's Avatar
Originally posted by EvilRoadsVictim
some things:
I had the same problem around this time last year... again.. i have it again... my uncle did something with the hoses to make it work (tightened it?) but now it doesn't work.. i'm gonna take it to him again so he can fix it.. but i'm not sure.. but i would also like to know since summer is almost here... (leather seats in the summer )
Old Mar 26, 2003 | 06:36 PM
AuToMaX_95's Avatar
thanks for all the help guys and ange
im gonne take it my car to local pepboys to check it out.. i hope nothing big is broken.
Old Mar 26, 2003 | 06:59 PM
Nismo's Avatar
I wouldnt even dare let pepboys touch anything. maybe its just in my area but they make things worse. anyways, does the compressor turn on? if so then chances are that theres a leak somewhere. Have a shop hook up some guages and see what the high-low side pressures are and see if it will hold pressure before you have them recharge the system so you dont waste money by having it leak out again
Old Mar 26, 2003 | 08:16 PM
AuToMaX_95's Avatar
Im sure my compressor turns on. Im currently taking auto classes in a Community college and the teacher is my loca pepboy Dispacher. So im pretty sure things won't get worse.
I think it might be a leakage too but aye... I don't know just have to let them check it out...Man there goes my $$$ for some stinkie mechanic who always over charge.
by any chance, is there any way a plug behind my dash could cause the problem? because last time when my AC work is before i took out my headunit after it casue warm air. But then again.... i plug all the wires back to the A/C. *there is only 2 extra wire next to the OEM plug for the headunit is not plug. And i can't find any where to plug it to.*
Does any one have a pix behind the dash? if anyone does please don't be lazy please post
thanks!
Old Mar 26, 2003 | 08:40 PM
Nismo's Avatar
thanks!
If your taking automotive classes then do you have acess to maifold guage sets at the school?
Old Mar 26, 2003 | 08:41 PM
97MaxGurl's Avatar
thanks!
no problem.. I went through 3 shops to get it checked out. Expensive lessons, just trying to help out.
Best thing to do is go to a shop that SPECIALIZES in auto AC. I wouldn't trust those Pepboys people b/c they only go thru 'standard procedure'. With that being said, there's a good chance they'll overlook things that 'experienced' ac mechanics will notice. Email me if you have time.
AnGe
Old Mar 26, 2003 | 09:10 PM
AuToMaX_95's Avatar
No acess to manifold guages because im only in the basic class right now, that class is a must before go on to high level, before then i can't use any of *specail tools* ...
I might have to beg my teacher to hook it up with a guage and check it... man =(
things a man would do for his car..... up
btw ange you got mail
thanks!
Old Mar 26, 2003 | 09:22 PM
Nismo's Avatar
No because im only in the basica class right now.. have to take that before go to high level... engin performance, electric, AC so on...
hummm, I know in our ac class we work on live customer cars so maybe see if they can do that for you. labor is free as long as you pay for parts needed.
Old Mar 26, 2003 | 09:29 PM
AuToMaX_95's Avatar
yeah we work on real cars too but then we don't get to use different type of special tools since is a intro class. Our school is getting a budget cut so everything is stric. Can't use this can't touch that blah blah blah...
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
