ATF Selection
Old Mar 28, 2003 | 11:20 PM
vipervadim's Avatar
I like Maximas
ATF Selection
Here's a question to all you automatic guys.
i'm going to be replacing the ATF and the power steering fluid as well, but i haven't found a very good brand of ATF.
I hear Royal Purple makes a good ATF and so does Amsoil and Mobil 1. But i haven't heard anything concrete yet.
i'm hoping you guys can clarify or recommend the best product.
What brands do you use and how have they been performing?
I already checked out "the spreadsheet" but it mainly covers motor oil.
thanks
-Vadim
Old Mar 29, 2003 | 07:33 AM
fisher01's Avatar
I'll be changing the atf on our maxima soon. Atfter reading posts here on the forum, I've decided to go with Mobil 1. I plan on using the method were one lets the transmission pump out several quarts and then you refill. This way I should get a complete flush.
Old Mar 29, 2003 | 10:19 AM
(_8*(l)Homer's Avatar
I used Pennzoil synthetic blend dexron-III mercon and have had no probs. Although it has only been in for about 2k miles.
I didn't know which one to use either.
Old Mar 29, 2003 | 10:52 AM
n2oMike's Avatar
I just use the regular ole' Dextron III. I drain the 4-5 quarts that will come out of the pan every 6k miles, and it stays perfectly clean and unburnt. It only costs around $6-$10, and I do it when changing the oil. No Problem.
Good Luck!
Old Mar 29, 2003 | 05:28 PM
iwannabmw's Avatar
Re: ATF Selection
thanks
-Vadim
Obviously I'm partial to Amsoil. Having said that, everyone that I know of who has used Amsoil's ATF has had a positive experience with it.
Old Mar 29, 2003 | 06:05 PM
mayhemI30's Avatar
"I'm running with scissors!"
Re: Re: ATF Selection
or redline is really good too.
Apr 16, 2020 05:15 AM
spidgeon
Jan 22, 2016 05:54 PM
mclasser
Aug 23, 2015 09:32 PM
follyburr
Aug 12, 2015 10:22 PM
