New NGK Plugs and a minor tuneup (Long)
Old Mar 31, 2003 | 07:02 AM
burrll_gee's Avatar
Ok i just got all new plugs( i dont think car ever had 60,000 tuneup). NGK Platinums, and a new filter for stock air box, brakes checked( were squealing thought it was wear indicators) and every fluid topped off.
Car drives amazing, Trememdous pickup after 2500 rpms, very clean and smooth startup now ( had stuttering problems in past, car not wanting to start properly). And i swear the engine just pulls harder and smoother! Going to double check the TB and ensure its clean.
Also going to run some Injector cleaner on next tank(Any reccomendations?)
I cant imagine how much a 5spd pulls if my auto can pull like this.
Summer WSP Y-pipe here i come! Maybe some new suspension too if i can afford it.
So to those with a 95 or 96 check your maintainance history and replace those plugs!
Old Mar 31, 2003 | 07:25 AM
fisher01's Avatar
Re: New NGK Plugs and a minor tuneup (Long)
For injector cleaner, i would suggest Chevron Techron. I've used it in all my cars with good results.
Old Mar 31, 2003 | 08:26 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: Re: New NGK Plugs and a minor tuneup (Long)
Yes, I have used the same. The Key to gettign the most out of it is to run it with a 1/4-1/2 tank at MOST. Also, manual shift (carefully!!!) so that you can get as close to redline as possible while still being halfway smart about it. Go WOT a few times (again, with descretion) to make sure that you get the injectors, etc, open as far as possible. On bottle each oil change keeps things running well.
Old Mar 31, 2003 | 11:50 AM
Mishmosh's Avatar
Injector cleaners
I was looking into this not too long ago.
Consensus was the following:
(1) BG 44k injector cleaker ($17-20), somewhat hard to find
(2) Chevron Techron ($6), easy to find
Also, use quality gas and you should not have problems with injectors.
Old Mar 31, 2003 | 12:13 PM
burrll_gee's Avatar
Kick a$$ you guys, thanks for the info/heads up.
I was gonna use OUTLAW fule injector cleaner/treatment.
But if Techron does it for $6 great.
Also i cant shift manually, im an AUTO. And how would that be any better than just WOT while in Park (intelligently of course).
I planned on using 1/2 tank Premium, 1 bottle injector cleaner, and going though revs to redline slowly 2or 3 times and then 1 or 2 times WOT until redline. This is what i did last summer after cleaning throttle body.
bg
Old Mar 31, 2003 | 01:19 PM
Entropy's Avatar
They mean shift carefully from L(1) to 2 to Drive(3).
If you had a manual, shifting manually would be the norm.
The reason they are emphasizing "carefully" is because the car will get to redline QUICK when you are romping on it. The first time you slap it on the rev limiter a couple times you will know what I mean.
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Excalibur23
Oct 13, 2015 04:33 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
