Brake upgrade
Brake upgrade
My car has about 80K on it and the brakes are driving me crazy. I had them turned by the dealer twice and the still pulse. How hard is it to do a rotor swap? What rotors would you recomend? Thanks...
Re: Brake upgrade
Did you swap your rotors yet? If so was it fairly easy? Hopefully I can avoid the dealer and do it myself.
I haven't done much work on this car yet, but I plan to start. I may do the OEM replacement and spend the money on new tires and a four wheel alignment.
Thanks again
Thanks again
I am getting Raybestus, I think. If not I will do Bendix. I have not done them, but from what I understand it can be done if you have any mechanical ability and a Hayne's or Chilton's manual.
www.motorvate.ca has instructions on how to replace rotors or other brake components
Get some $30 rotors from autozone and do it yourself. $60 + 1 hour (first time labor) is not bad for a brake job. Replacing brake rotors is insanely easy. Take off the wheel. Take off the caliper (2 14mm bolts) and take off the caliper bracket (2 17 or 19mm bolts) and use a rubber mallet to bang the rotor off the hub. Reverse process and you are done.
I was wondering, are the breaks supposed to be horrible when the car is in neutral? I'm still kind of new to driving manual, and my friend says its always better to brake while in gear. I usually do this, but sometimes I'll just pop it in neutral and coast to the red light, and when I try and stop, I really have to bite into the brakes. They don't respond well at all in neutral, but they're okay in gear. Should I get them replaced soon? A little while ago my mechanic said they probably have about 5000 miles left in them, but my car is a 98. Brakes should last longer? Thanks for the feedback, and letting me post this on the thread.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
