Help - ABS Sensor stuck
Old Apr 1, 2003 | 10:09 AM
genepool's Avatar
I have to replace the front right hub and I noticed that my abs sensor is frozen in there (I tried to remove it before..). After taking out the bolt, it won't budge. I even cracked the plastic casing before i realized it was plastic . How do I remove it? I really don't want to pay $100 for a new sensor
Old Apr 2, 2003 | 05:54 AM
genepool's Avatar
bump
Old Apr 3, 2003 | 08:12 AM
genepool's Avatar
Originally posted by genepool
bump
another bump...
If anyone reads this that has search capabilities , can you search for me. thx
Old Apr 3, 2003 | 08:28 AM
sinewave's Avatar
Well, I checked the '99 FSM and there isn't a whole lot of info there on removing the sensor. It has a diagram of the location, a torque spec for the bolt (13-17 ft/lbs) and the following text:
"Removal and installation
CAUTION:
Be careful not to damage sensor edge and sensor rotor teeth. When removing the front or rear wheel hub assembly, first remove the ABS wheel sensor from the assembly. Failure to do so may result in damage to the sensor wires making the sensor inoperative."
From the drawing, it looks like you could remove one bolt and then gently pry the plastic sensor out with a small screwdriver. Wedge the screwdriver in between the sensor and the hub mount. If you broke the housing, you may need replace it. At the very least, glue it back together to keep water and road grime out.
Old Apr 3, 2003 | 10:35 AM
genepool's Avatar
CAUTION:
Thx for the response. I too followed the FSM and there is no mention of how to remove the sensor, I'll go and double check the haynes manual tonight. I tried to wedge a screw driver between the sensor and the housing and that's how it cracked and I realized it was plastic . Also, the abs sensors changed after 96 so getting a used one could be difficult.
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
