I have wear on the inside of my back tire. Why?
Old Apr 6, 2003 | 01:56 PM
maxfanfromohio's Avatar
Shiver me timbers.
I can hear a clunking sound also when I go over bumps. It sounds like it is coming from that side. Could someone tell me what might be going on? All opinions are appreciated.
Thanks,
Fred
Old Apr 6, 2003 | 02:08 PM
patel_anu's Avatar
you probably need an alignment
Old Apr 6, 2003 | 02:10 PM
Sprint's Avatar
stock shocks and springs?
Old Apr 6, 2003 | 02:22 PM
Shiver me timbers.
Yes, I am still rolling stock. Watcha thinking Sprintmeister?
Old Apr 6, 2003 | 02:26 PM
Sprint's Avatar
clunking is usually due to incorrect install of springs and struts.. maybe you need an alignment and balancing as mentioned before
Old Apr 6, 2003 | 02:29 PM
Shiver me timbers.
I thought we only got front wheel alignments. Will this help the rear? I will get the tires rotated and balanced. What about ball joints? Are they possibly a culprit?
Old Apr 6, 2003 | 02:36 PM
Sprint's Avatar
well if the front is off.. the rear will be affected too..
not too sure about the other questions
Old Apr 6, 2003 | 03:27 PM
Kevin's Avatar
my thoughts....
The rear axle beam is not adjustable on 4th gen's I think....
There probably are minor adjustments they can make but I'm pretty sure the rear can't really be aligned they way the front can.
What you should check is, see if the rear Axle beam is bent, see if you have look at the car on a lift.
Old Apr 7, 2003 | 10:57 AM
Shiver me timbers.
Anyone else, any opinions?
Thanks.
Old Apr 7, 2003 | 11:15 AM
njmaxseltd's Avatar
Have you been rotating your tires?
Maybe the front is out of alignment and the ware you now see is actually happening when that tire was on the front end.
The noises do indicate something isn't right back there.
If the rear shock was bad you'd get a bouncy ride and bumps would impact pretty harshly. But being the beam is solid and the alignment is fixed, the tire still wouldn't ware on one side. Only the ride would be effected and the tread may become cupped.
If indeed that tire is waring on one side while it's on the rear of the car, have a shop put the car on an alignment rack to see whats off or loose in the rear end.
Old Apr 7, 2003 | 11:16 AM
dwapenyi's Avatar
Yes, and to add, most tire wear occurs when your tires are on the front. The rears are just chillin'. It would take a really really long time for uneven wear to show up on the back if you don't rotate your tires at all. Perhaps your front end needs the alignment, assuming you rotated the tires regularly , Maxfan.
DW
Originally posted by Kevin
my thoughts....
Old Apr 7, 2003 | 11:22 AM
Shiver me timbers.
Thanks everyone for your opinions. I will get my suspension looked at ASAP and have the tires rotated and my front end alignment done.
Old Apr 7, 2003 | 11:35 AM
rmb's Avatar
rmb
Clunking sound= Dead shock, wrecked mounts/bushings, broken spring.
Inner tire wear= Faulty tire(unlikely) or Bent rear suspension. No adjustments possible. Replace parts as needed.
A little 5mph slide on snow into a curb sideways a few years ago really wrecked my suspension.... it doesn't take much going sideways....
-RMB
Old Apr 7, 2003 | 11:46 AM
greenmax95se's Avatar
i better stop going side ways before i wreck my rear
Old Apr 7, 2003 | 11:58 AM
mymaxlvsattn's Avatar
slackass
I had the same problem and it turned out that i had a bent spindle. Whoever owned the car before me musta hit a curb or something. had to have the whole think replaced..set me back $375
JRod28
Dec 29, 2023 09:56 PM
Starrider
Sep 17, 2015 07:26 AM
acw
Aug 13, 2015 12:50 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
