directions on how to get seats out ASAP PLEASE
Old Apr 8, 2003 | 07:43 AM
PaulCT's Avatar
in the middle of install and i lost the page i printed on how to take the back seat out to put the speakers on. it had pictures. i know its easy can someone post a link PLEASE thank you
Old Apr 8, 2003 | 08:16 AM
nupe500's Avatar
Jedi Knight
gently lift up on the bottom and see the little plastic thingy...pull it out (towards the front of the car) and pull the seat up...repeat for the other side.
Old Apr 8, 2003 | 08:20 AM
Requin6's Avatar
Re: directions on how to get seats out ASAP PLEASE
the lower portion of the rear seat clips in, the clips are located at the legs of the left and right seats. there is a ring that pulls back and you lift the seat up and pull it out. the upper portion (seat back) is held in with 4 10mm bolts. once the lower portion of the seat is removed you can see 2 of the bolts located where the seat belt anchors to the chassis. they are holding down a long U-hook that holds the bottom of the seat in place. for the last 2 bolts pull down the armrest and lift the gray cover piece up and there are 2 more identical 10mm bolts. remove those and the upper portion is ready to be removed. on the back of the upper portion it is held in by 3 grooves...just lift upwards on the seat unhooking the 3 hooks. there is one on the left, middle and right of the seat. thats all. hope that helps you out.
--Paul
my03maxima
Jul 28, 2024 07:40 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
sliptap
Sep 30, 2015 05:57 AM
