Redline MT-90
Old Apr 9, 2003 | 01:48 PM
djshawnee's Avatar
Redline MT-90
Hey guys, I can't find the Redline manual tranny oil anywhere! Well, I only looked in 2 places, but that's all I have here. I looked for the Amsoil stuff too. The only synthetic oil I could find was some Mobil 1 stuff. How is this compared to Redline/Amsoil? I need 80W-90 that is at least GL-5 rated, right?
Also, what is the best kind of motor oil for my car? I have almost 80k miles.....
Thanks!
Shawn
Old Apr 9, 2003 | 01:59 PM
Dev's Avatar
Dev
Re: Redline MT-90
Thanks!
Shawn
you should be using 75W90 GL-4
Old Apr 9, 2003 | 02:02 PM
djshawnee's Avatar
doesn't GL5 also work on GL4 cars? correct me if im wrong.....
Old Apr 9, 2003 | 04:08 PM
Jason R's Avatar
aka UNCDooD
Redline Products
Originally posted by IceY2K1
www.myoilshop.com
Enter dealer code #675421 for 10% off.
Old Apr 9, 2003 | 04:13 PM
bb0ys's Avatar
How many quarts should I buy to fill the transmission?
Old Apr 9, 2003 | 04:17 PM
iwannabmw's Avatar
Sometimes. The GL5 spec calls for double the amount of extreme pressure additives. These can attack the softer metals in a tranny designed solely for a GL4 lube. The high quality synthetic lubes have a chemistry that prevents these additives from attacking the softer metals allowing them to be safely used in a GL4 tranny. If you use a conventional GL5 lube, more than likely you will have some issues.
Old Apr 9, 2003 | 04:20 PM
iwannabmw's Avatar
Buy 5.
Old Apr 9, 2003 | 04:27 PM
marcdown20's Avatar
Originally posted by iwannabmw
Buy 5.
i've always used 5 and alittle bit... to make it completely filled...
Old Apr 9, 2003 | 07:07 PM
nativemax's Avatar
The MT-90 is perfect for what you need, GL-5 shouldn't be used for transmissions that require GL-4 because of the additive package that can make for harsher engagement.
Old Apr 9, 2003 | 07:13 PM
StygianMax's Avatar
Stay away from GL-5. If you're thinking of changing the tranny fluid yourself, I have pics/instructions that can help you on pg. 7 of my homepage.
Old Apr 10, 2003 | 07:56 AM
marcdown20's Avatar
so GL-5 refers to the 80W-90 tranny fluid? can u get GL-4 at most autozone type places?
mike
Old Apr 10, 2003 | 10:29 AM
iwannabmw's Avatar
mike
Not necessarily. There are GL4 80W-90's and there are GL5 80W-90's just as there are GL4 75W-90's and GL5 75W-90's. It's very hard to find a conventional GL4 gear oil at an auto parts store, they mostly have the GL5 lubes. In the synthetic area, you'll find oils that can safely meet GL4 and GL5 without harming your transmission in both 75W-90 and 80W-90.
Old Apr 10, 2003 | 12:46 PM
n2oMike's Avatar
If you want Redline, call Summit Racing and ask for it.
1-800-230-3030
They keep it in stock. It ships VERY quick. It comes from Ohio. I live in West Virginia, and it gets here the NEXT DAY via UPS if I order it in the morning. Yes, that is regular ground UPS.
http://www.summitracing.com
Good Luck!
Old Apr 10, 2003 | 01:01 PM
DSimple1's Avatar
You can also try www.myoilshop.com, its $7/quart, thats the best price ive been able to find... there was a coupon code out there too that gave 10% off, but I dont know where I found it.
Old Apr 10, 2003 | 01:51 PM
mitch33x's Avatar
www.myoilshop.com
as stated above
Old Apr 10, 2003 | 02:33 PM
marcdown20's Avatar
so i should be using GL-4, 80W-90 or 75W-90? i think i'll end up going w/ the redline stuff but need to make sure i have enough money to do that...
mike
Old Apr 10, 2003 | 03:31 PM
iwannabmw's Avatar
mike
Yes. If you decide to go with Redline, just buy the MT-90 and you won't have to think about anything else.
Old Apr 10, 2003 | 04:04 PM
marcdown20's Avatar
i also see you're an Amsoil dealer... would you suggest that instead? and how good of a price can you get on that for us?
mike
Old Apr 10, 2003 | 04:12 PM
Jason R's Avatar
aka UNCDooD
your how-to came in very helpful when I had to replace an axle seal in my transmission. just wanna say thanks.
Old Apr 10, 2003 | 04:23 PM
patel_anu's Avatar
what about automatic transmissions?...which one would i need:
Racing ATF
D4 ATF
C+ ATF
Synthetic Dex II ATF
or High Temperature ATF
Old Apr 10, 2003 | 05:59 PM
StygianMax's Avatar
Glad to contribute a little something back to org'ers after I've gotten so much benefit from everyone else. btw, www.motorvate.ca has a LOT of really good how-to's! Now there's a site that rocks.
Old Apr 10, 2003 | 06:20 PM
iwannabmw's Avatar
mike
Both Amsoil and Redline are excellent products. Which one is better for you is a subjective questions. Amsoil offers better wear protection and Redline will have the edge in low temperature shift quality.
Amsoil's Series 2000 75W-90 is the best gear oil for applications where the car is worked hard and is the one I use and recommend. It's $7.56/quart. There are also 2 other gear oils available for consideration as well if the Series 2000 is too much overkill for your needs.
Redline ATF for the Max would be the D4 ATF.
user 11122324
42
Jul 18, 2022 03:35 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
3rdmaxse0
Aug 18, 2015 08:25 AM
1997 Maxima SE
Nov 24, 2000 01:37 AM
