Are these worth it? Need Feedback- Headlight Bulbs
I was wondering if anyone has these headlight bulbs. Are they good, are they worth it, do they last? Thanks
http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
or these ones?
http://cgi.ebay.com/ebaymotors/ws/eB...category=36476
Originally posted by JC96max
You need an upgraded headlight harness if you want those high wattage bulbs to last.
very true...I told my friend who recently bought a set like those, but he doesnt believe me....he'll soon find out....
Also, he has similar lights that looks whitish blue, and they just dont put light down like my Phillips BlueVisions. They arent blue by any means, they have a whiter appearance than stock and are brighter. I would stay away from lights that say "HID" "next best thing to HID" and "Xenon"
just my .02
eric
Bought the XD5's (newer version, same company) and found them to be too blue for me. My $ was refunded promptly, no questions asked.
Beware if you're using those pics. on the website to gauge your expectations. I think the same pics were used to advertise the XD5's and to be honest, there was either some Photo-shopping going on, or the photo image just didn't accurately represent the color of the lights on the road.
They were definitely BLUE on the road, which translates to poor visibility in the wet.
-my .02 cents.
-my .02 cents.
Originally posted by WOODYMAX98
What headlight bulbs do you recommend, nothing to expensive? Also where can i upgrade headlight harnesses?
I think I'm going to try the Sylvania Extravisions next. I read several good reviews on them - many .org-ers have them & seem happy with the light output over stock.
I believe they're available in stock wattage at Kmarts and many other retailers for less than $25 a set.
Silver Stars
I bought a set of Silver Stars last week and as time passes on the more I like them. At first I didn't see a great improvement but as I drive on different roadways at night, I see a big difference. However it still hasn't rained here in Austin so I don't know what they look like in the rain...They are pretty pricey though...$50..
Go Marines!!!
Go Marines!!!
I had the Silverstars and they were great until it rained. To much glare on wet pavement. Right now trying the Wagner Britelites and Sylvania Xtravisions. Just my two cents. Also, how are the PIAA Xtremes in the rain? Any glare? Thanks.
Pedro
Pedro
Originally posted by pruizgarcia
I had the Silverstars and they were great until it rained. To much glare on wet pavement in my opinion. Right now trying the Wagner Britelites and Sylvania Xtravisions.
How are the PIAA Xtremes in the rain? Any glare? My upgraded wiring harness is also on order. Thanks.
Pedro
Pedro
Want a slightly whiter look, then go with Philips BlueVision. You can get them at Kmart for about $9 per bulb. I've done some comparisons and for the price these are one of the better 9004 bulbs, which actually help.
If you want blue/ HID, most bulbs will make your vision worse because they use too much of a blue coating to filter the yellow.
You should just buy HID's. I had over 5 sets of bulbs in my car and all I can say is WOW HIDs OWN!. I had Silver stars for a day, and I think that they are too overpiced for what they do. I rather use stocks then Silver Stars. I Also had the first ones u posted, and they melted my sockets, If you buy those make sure you upgrade your hardness. But trust me you won't regret the HID's. Best $379 I've spend on my car.
where can you buy upgraded harnesses? And how did they look besides the fact that they ruined your harnesses.
Originally posted by EvilRoadsVictim
no save your money. the 'comparisson' images are photoshopped. get 1.80$ halogens or leap for real HIDs. everything in between will eventually not keep you happy.
What about these MTECs? The output is supposed to be 170Watt.
other than melting your harness instantly, you will absolutely blind drivers if its really 170watts...No point in 170watt lights, a much much lower wattage bulb can be "brighter" than a higher wattage bulb, dont always go with watts, i believe the amount of lumens in a bulb is what produces its brightness...look at that...
eric
eric
eric
Despite this seller's claims of the bulbs being safe for the OE wiring harnesses, I'd want a better explanation of their whole wattage rating and "technical" explanation. (-Not very technical at all, if you ask me - just a lot of mumbo-jumbo sales doublespeak).
Btw, I read the whole auction & their wattage rating with their explanation that the bulbs draw the "same as stock" wattage: seems to be a contradiction to me, unless they can explain otherwise.
eric
eric
i soooooooo learned my lesson!!!
get the harness!!!!!!!!
from reading this thread.. it seems to me that Lighting is a priority for maxima go-ers. I currently use the SilverStars. IMO.. A lil overpriced. The light has blue tint at the tip which gives off a very slightly blue glare (mosty likely for cosmetic resons) which atrract attention of the consumer which makes you spend 40 bucks for a pair (like i did). Def whiter and brighter, and dark roads the high beam seems bright blueish but def improvement over stock. Youll get the same results with the cheaper Xtravisons. Same concpet (whiter brighter light) but no cosmetic bull**** as an excuse to charge 20 bucks a bulb. If your low on cash and dont want new harness, just get xtravisions.
Originally posted by supercobraz
Did you upgrade your harness for the Silver Stars? Is it nessecary or just being causious?
Piaa and a few other companies will describe their bulbs as 80/100 light output, but if you look close you'll notice that the Wattage draw is only 45/55, so these don't need a harness.
Originally posted by breaux124
You don't need an upgraded harness for these bulbs. The only bulbs you should get an upgraded harness for are bulbs with a rating over the factory spec of 45/55 (I think)
Did I see correctly??? $65 for the PIAA H3 fog bulbs...That's alot...I'm trying to find fogs to match my Silver Stars but I don't want to pay as crazy of an amount as I did for the Stars themself...
eric
you probably did, PIAAs are overpriced...period...no ifs, ands, or buts about it.....
eric
eric
Originally posted by KiLIAkLoWn
Yes they are, but they are great looking bulb. Its like buying Tommy jeans over Levis. Tommys are overpriced but they have the look your looking for.
eric
I have the Piaa Superwhite headlights, and I think they're overpriced. I've done side-by-side comparisons with the Philips Bluevisions, looking head on, and driving. I can say that these two bulbs are almost exactly the same. I can say that they Piaa's have lasted me close to three years now, so I've got my money's worth.
I can't say anything about the xtreme 9004 headlights since I've never had them, but I do have the H3 xtreme fogs. The h3 fogs are better than stock and are worth it(if you get a good deal). I bought mine off ebay and it was much cheaper than most stores.
There are two types of wire harnesses that I know of.
The more expensive type uses a relay and completely new wire that directly connects to the battery. This type is easily removeable and the wires are independent of the car's factory wiring.
Example here:
http://cgi.ebay.com/ebaymotors/ws/eB...category=34207
The second type upgrades the stock wire connector, but I think this requires some type of splicing into the factory harness. I've never used this type so I'm not really sure how it installs.
Example here:
