Motivational Strut Mount Install Question
Old Apr 10, 2003 | 03:32 PM
Asian_N02's Avatar
The question is about the black strut mount with the two holes on each side. When I put the screws in and get everything squared away (spring mounted on the strut and tightened down), I get ready to bolt it down to the chassis. When I start screwing the nuts onto the strut mount screws (provided), the screws I installed on the strut mount become undone, causing my spring to unseat, but more importantly, I cannot tighten the strut down to my chassis because it will not go down any further on the provided screws.
Has this happened to anybody? If so, or if you are just reading, what are your suggestions? Thank you!
Old Apr 10, 2003 | 04:49 PM
drewm's Avatar
I thought the screws were integrated into the strut mount, and weren't seperate, that's how mine was.
I did have a little problem with the spring unseating while installing, and assembled the strut in a slightly different order than mine gave in his diagram, basically reversing the top two washers to keep the mount from tilting.
from top to bottom:
top nut
upper washer
stock rubber washer (bump pointing up)
ribbed rubber washer (bump pointing down)
motivational mount (screws pointing up)
urethane washer (provided) (bump pointing up)
metal washer (provided)
bumpstop
Old Apr 10, 2003 | 05:20 PM
Asian_N02's Avatar
My screws were not integrated into the mount. Not the ones I received from Motivational. I could not get the set up you described. I had spring compressors and could barely fit everything on there. Thanks for the help though.
Old Apr 10, 2003 | 05:37 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: Motivational Strut Mount Install Question
Apply some threadlocker like Loctite Red on the threads and screw the bolts in tight. Wait a day then assemble the damper assembly. Good luck in trying to unscrew again. This is what I'm planning to do to my MSM (new acronym ) when I install mine.
Old Apr 10, 2003 | 09:20 PM
MaxWolf's Avatar
just so we are on the same page...those that bought these earlier, and those who have recieved them recently..is this what you have all recieved?
Old Apr 10, 2003 | 09:27 PM
MaxWolf's Avatar
rbuswell
Nov 17, 2016 04:54 AM
JRod28
Feb 4, 2016 11:07 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
