How to install stillen front lip
Old Apr 10, 2003 | 07:01 PM
AuToMaX_95's Avatar
I just receive my front lip today. I would of search and check out HOW TO section on maximadriver.com but both are down.
So please any information would be great
thanks!
Old Apr 10, 2003 | 07:05 PM
PCGuRu2K's Avatar
Re: How to install stillen front lip
thanks!
Did you get a bag with screw, rivets, tape, and instructions ?
Well basically you wanna put tape on the top of the lip so it will go around the bumper. Then you can either use rivets or screw it in the fender on the sides.. I would use rivets so someone just doesn't unscrew the lip and rip it off..
Old Apr 10, 2003 | 07:09 PM
97blackSE's Avatar
not to be a (post) *****...but i am about to install one too, any specific tips/things to avoid?
Old Apr 10, 2003 | 07:11 PM
PCGuRu2K's Avatar
Just make sure the surface is clean and dry.. Use some primer on the double sided tape too so it can stick better.. Also test fit it first and make sure it looks ok. It'll make it easier to install so you know exactly where it will go to sit flush.
Old Apr 10, 2003 | 07:17 PM
AuToMaX_95's Avatar
yeah i got a bag of screws and instruction but when i look at it i was
the only thing that seems understandable to me is the 3m tape other than that screws and etc I have no clue where to poke it.
a picture would be really really nice.
thanks for the info btw !!
Old Apr 10, 2003 | 07:24 PM
ZeRo MaX's Avatar
what are the specs of them screws... i still need to put mine on...
do you just SCREW it on?
Old Apr 10, 2003 | 07:49 PM
AuToMaX_95's Avatar
do you only screw it on the side.. into the fenders? any where else?
Old Apr 10, 2003 | 08:44 PM
sil SE's Avatar
bah, just screw that sucker in. maybe a little tape. ghetto
Old Apr 10, 2003 | 09:32 PM
I H8 COPS
Re: Re: How to install stillen front lip
I'm not sure where it was, perhaps maximadriver.com (but not sure) that specifically said not to use the tape unless you live in dry areas such as Arizona, etc. Winter conditions will have bad influence on the tape or something of that sort. Anybody else hear of that? I'm very serious.
Old Apr 10, 2003 | 09:48 PM
AuToMaX_95's Avatar
Re: Re: Re: How to install stillen front lip
really? i think i might of saw that on Maximadriver.com but the site is down so ican't check it. But i live in LA and is always sunny here so i guess is ok.
I need to know how many screw goes on each side of the fender? what about the bottom of the lip or the bottom front?
any suggestion?
Old Apr 11, 2003 | 04:16 AM
BRIGBOY's Avatar
1 rivit or screw into the sheet metal of each fender. Pre drill this hole in both the lip and fender edge. As for the front lay underneath and pop a few screws into the middle if you want.
From my experience, The tape is not really for the front. Use the tape on the sides in the door jambs thats it.
Just screw through the middle underneath into the stock bumper cover. It will tighten up the small gap you see.
Its not rocket science but it is trial and error until it fits to your personal liking. After all, your the one that gets to run it over if it falls off
Old Apr 11, 2003 | 06:23 AM
amixam98's Avatar
Needs non-Maxima Friends
I used 3M double sided tape and one screw on each end. One of my friend just use tape all around the lip and she hasn't have any problems. Both of us are in Mass.
Old Apr 11, 2003 | 07:32 AM
ZeRo MaX's Avatar
it hasn't fallen off or anything..
you screwed it on the fenders right..
what size screw do i use... i just screw it in.... make a hole and screw it in...
Old Apr 11, 2003 | 10:02 PM
AuToMaX_95's Avatar
how do you use rivets ? and i try to screw the middle underneath, it didn't work any other suggestions on tighetn the gap in the front?
sonic7
Aug 20, 2015 12:23 PM
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
