CV boots and strut
Old Apr 11, 2003 | 04:07 PM
Monil's Avatar
CV boots and strut
I have a '95 max with 78k. My front cv boot is torn. Question is what happens if I don't get it replaced? Also I was told by my mechanic there is a slight leak from the left rear strut. I noticed only a little fluid on the strut. What happens if I don't get that replaced immediately?
Old Apr 11, 2003 | 04:17 PM
Nismo's Avatar
the cv will wear out and cause alot of noises and may eventually destroy itself. the struts are ok if worn out if you dont mind having the car bounce up and down all the time. wipe off the fluid off the strut and monitor it from time to time to see if its really a leak
Old Apr 12, 2003 | 05:04 AM
Monil's Avatar
Thanks for the reply! I was quoted for the cv joint. Can I just replace the torn cv boot or should I repalce the cv joint?
Old Apr 12, 2003 | 03:51 PM
jerseymax's Avatar
depend on how long its been torn for and if there is a lot of crap inside..
my drivers side just tore as well on my 95 se..
makes noise when i do tight turns..
Old Apr 12, 2003 | 06:39 PM
Nismo's Avatar
my auto teacher gave us an estimated 8 hours from the time its torn to the time it must be replaced. rebuilt axles go for about $90 each so maybe you can order one and just have the shop install it to cut down on labor instead of having them rebuild your cv
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
