Squeeling sound at starting
Old Apr 12, 2003 | 12:53 PM
Max-2-GTR's Avatar
I know this has been asked a lot of times but I would like to have a simple answer. When I start my car, there's a squeeling sound that seems to be coming from the driver side of the engine so it isn't probably the belts and I heard that if it's on the driver side, it could be the starter. If thats the problem, is that a DIY job? and is there any more reason why the car could sound like this?
Old Apr 12, 2003 | 12:55 PM
gtr_rider's Avatar
192.168.1.1
Re: Squeeling sound at starting
Starter is a DIY job, but I never heard a starter squeel
Old Apr 12, 2003 | 01:01 PM
Tapio's Avatar
That squeeling sound is typical of a loose or worn belt. Highly doubt it's the starter and the most common belt in question is the Alternator belt.
Usually it takes nothing more than just tightening the belt up. Don't replace it if it's not necessary.
Old Apr 12, 2003 | 03:55 PM
Dave B's Avatar
Not DAVEB the parts guy
Yep.
Dave
Old Apr 12, 2003 | 04:56 PM
BadKarma99-4spd's Avatar
and if your really really lazy you could get some anti-squeel and spray that in there
Old Apr 12, 2003 | 04:58 PM
ZeRo MaX's Avatar
hmm.. where can i get that at (anti-squeel spray)...
how long does it take a belt to worn out...
which way do i turn the nub thing off of the pulley to tightn or loosen the belt?
Old Apr 12, 2003 | 06:17 PM
OpTikOl's Avatar
belts
i had the same problem before and after changing the belts. It may not necessarily be the belt itself that is worn out, you have to make sure whoever changes it for you TIGHTENS the belts correctly whether it's the alternator crank belt or AC etc... Check to make sure they are as tight as possible and the squeeling will go away
Old Apr 12, 2003 | 11:06 PM
Max-2-GTR's Avatar
Re: belts
I heard that tighting the belts too much will lead to a leak. I dunno where but a leak...
Old Apr 12, 2003 | 11:16 PM
masterB's Avatar
any link to a write up for tighten the belt?
Old Apr 13, 2003 | 08:02 AM
maxmobile's Avatar
WD40 should do the trick.. but ur better off replacing the belt or adjusting it...
Old Apr 13, 2003 | 08:18 AM
gtr_rider's Avatar
192.168.1.1
www.motorvate.ca
Old Apr 13, 2003 | 02:59 PM
Max-2-GTR's Avatar
Originally posted by gtr_rider
www.motorvate.ca
Since the squeeling sound comes from the right, do I have to do everything where they say top, bottom , left middle? what are these? I'm a little confused with what they say.
DJLAX152
May 4, 2021 11:46 AM
97_GXE
Sep 15, 2015 06:47 AM
TheMafia
Sep 4, 2015 08:26 AM
