My Rotors Are Very Thin...Help!!
Old Apr 12, 2003 | 03:39 PM
maxperformance's Avatar
My brakes have been making very weird noises lately, i noticed that on all four of my brakes it seemed that my pads were ok but my rotors were very thin and worn. My braking has become weaker, so what should i do? I would love to get aftermarket slotted or drilled rotors, but i dont have crazy money. Would it be cheaper to just go to the dealer and have them do it. Please help me out on some good sites or recommendations for me. Thanx guys
Old Apr 12, 2003 | 03:43 PM
Nismo's Avatar
www.southwestautoworks.com has some brembo with slots/drilled for a good price. if they are not that bad then you can just get them resurfaced and new pads
Old Apr 12, 2003 | 03:52 PM
njmaxseltd's Avatar
How do you know they are to thin? Did you measure them with a micrometer?
The minimun thickness (measured in mm) of the rotor is usually found cast into the rotor somewhere. The Haynes manual doesn't have the measurement.
Old Apr 12, 2003 | 04:07 PM
StygianMax's Avatar
My rotors are completely rusted wherever the pad does not come into contact with the rotor. Does anyone know what the min. thickness is?
Old Apr 12, 2003 | 04:54 PM
BadKarma99-4spd's Avatar
rotors
i bought brembo replacements(blanks) from tire rack they were like 218 total for all 4 and shipping. i was able to put them in myself and the improvment over my old ones is amazing
good luck
Old Apr 12, 2003 | 05:13 PM
rmb's Avatar
rmb
All rotors are made of cast iron. Rust is normal.
Cast iron + heat + water = rust
Cast iron + heat + water + salt = more rust
When you replace the pads, get the rotors turned at a good machine shop. They'll shave off a wee bit and return the surface to like new. Or like the man said just get four new solid Brembo blanks and you're stylin. They'll still rust. Don't bother with cross-drilling or slotting, that's stupid on a street car and does weaken the rotor. Unless you like the way it looks it's not going to make you stop any faster.
woohooo -
-RMB
Old Apr 12, 2003 | 05:22 PM
StygianMax's Avatar
woohooo -
-RMB
Oh yeah, they use lots of salt in the winter where I am!
I was told by my mechanic my rotors are too thin to machine. I've got 4 new ones in the basement (2 brembo fr., 2 discounted oems rear) + new front pads. Now I just have to find time.
A buddy here wanted to measure the thickness of his rotors with my micrometer so I wanted to know what the min. thickness is.
Old Apr 12, 2003 | 05:53 PM
rmb's Avatar
rmb
It should be stamped right on the rotor near the hub. Sometimes it rusts off though....
-RMB
Old Apr 12, 2003 | 06:18 PM
StygianMax's Avatar
I was able to read the min. thickness #s off from my new rotors that are still boxed. From Brembo fronts (20mm) & oem rears (8mm).
Old Apr 12, 2003 | 06:25 PM
MAXIMARK's Avatar
rustless...
PowerSlot rotors come cadmium plated so the Hat and rotor edge don't rust. They are one and a half times more expensive than the other mentioned brand... Just finished installing a complete set today.
Stopping Safely, Mark V.
Old Apr 14, 2003 | 07:21 AM
have you ever heard of anyone saying that shops wont machine those rotors because they are cadmium plated? i was thinking about getting those but i read a thread somewhere that they couldnt be machined down?
Old Apr 14, 2003 | 08:25 AM
StygianMax's Avatar
I think the problem in machining is because of the uneven surface with x-drilled and slotted rotors rather than the fact the rotor is Cd-plated.
Old Apr 14, 2003 | 09:38 AM
got ya
Old Oct 4, 2009 | 10:07 AM
cobradb's Avatar
min thick for 07 maxima fr rotor according to the local parts is 1.024 in. before turning.
Old Oct 4, 2009 | 10:29 AM
max ride 41's Avatar
where do you noobs find these old threads?? almost 7 years old!!!! learn to look at dates dude!!!
Old Oct 4, 2009 | 04:07 PM
Alpinestar2007's Avatar
i do belive the uneven surface is thereaso shops won't machine them.
Old Oct 4, 2009 | 04:14 PM
Viperoni's Avatar
Never buy drilled rotors for street use, but slotted and dimpled are a great idea IMO.
Old Oct 4, 2009 | 06:35 PM
Conrad283's Avatar
I need a truck
This is the 4th gen forum, so why would you post about the thickness of a 6th gen?
Say wha???
Old Oct 4, 2009 | 07:55 PM
pmohr's Avatar
No more Maximas...
I see three fails here.
You fail for the following reasons:
  1. This is a 6 year old thread.
  2. This is the 4th gen subforum, where an '07 is obviously out of place.
  3. Discard for the A34 front brakes is 1.02 inches. Not before turning, but whenever they pass the discard, they are to be...discarded.
Look before you post next time.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
