EVAP Control Sensor- Code 74
Old Apr 12, 2003 | 06:40 PM
dihahs's Avatar
Does anyone know where I can get an EVAP control Sensor- Service engine soon light is on in my 98 maxima se, and the code is 74. Also, what is an EVAP canister valve? What exactly does the EVAP control Sensor do? Please help!
Old Apr 12, 2003 | 07:57 PM
pruizgarcia's Avatar
Re: EVAP Control Sensor- Code 74
Well, I got the 0705 Evap Control System this morning. Now I have to find which part of the Evap system is causing this error.
Pedro
Old Apr 12, 2003 | 09:30 PM
Grey00lustre's Avatar
u can actucally take it apart..clean all the pieces and spray some wd40 on it...put it back together and reset the cel...this should fix the problem...
Old Apr 12, 2003 | 11:57 PM
krismax's Avatar
Father of the 00 VI
Re: Re: EVAP Control Sensor- Code 74
Pedro
0705 evap system leak
Old Apr 14, 2003 | 03:47 PM
breaux124's Avatar
I just got this code 0705 and 0903 together. For me, I think it was because my gas cap wasn't completely on. I rescrewed the cap back on, reset the ECU and it's hasn't gone off again today (to and from work)
Old Apr 14, 2003 | 04:15 PM
BBaker025's Avatar
I got 0705 and 0903, my gas cap is on tight. How do I clean the EVAP system?
Old Apr 15, 2003 | 04:22 PM
MGokool's Avatar
I got the code 7-4= EVAP pressure sensor and 2-15 which I dont know what the hell it is....any help for me?.
What can i do to resolve the problem?
Old Apr 15, 2003 | 04:52 PM
Juki5536's Avatar
I got P0440 and P1448 from my mechanic. He wants me to leave the car so he can see where the problem is coming from. I think its the same thing, EVAP Control Sensor. Help! Don't wanna leave it a whole day!
Old Apr 16, 2003 | 01:37 PM
My 0705 code turned out to be a bad gas cap. It wasn't creating a good vacuumed seal which in turn triggered the 0705 error code.
Pedro
Old Apr 16, 2003 | 01:52 PM
hokiemax's Avatar
I have the 0215 too. Its EVAP canister solenoid malfuncion.. Does the FSM or Haynes show the steps to clean the EVAP system? I lost my FSM so I dont know..
Old Apr 16, 2003 | 02:13 PM
MGokool's Avatar
Thank you for the info...whats your email addy...I have to look at the manual about steps to clean when i get home tonight...i'll post back later! < at work now >
Old Apr 16, 2003 | 02:32 PM
maxspeed96's Avatar
0215
The Haynes manual says that the vent control valve is closed on the EVAP.
Old Apr 16, 2003 | 02:38 PM
maxspeed96's Avatar
P0440 is the same as 0705- EVAP system leak
P1448 is the same as 0307- closed loop control fault (right bank)...whatever that means
Old Apr 16, 2003 | 02:58 PM
spiff56747's Avatar
wow this really needs to be made into a sticky. code 0704 has literally been asked at least once a week for the past few weeks while the search has been disabled.
Old Apr 16, 2003 | 03:28 PM
eclypsecl's Avatar
sounds like EVAP canister purge volume control valve 0810 are related to what u guys are getting..any ideas where the evap control valve.
Old Apr 16, 2003 | 04:19 PM
MGokool's Avatar
just curious...what everone here with EVAP problems, what was your mileage when problem started...just curious. And, everyone has this problem, anyone there with any possible solutions?
Old Apr 16, 2003 | 04:35 PM
eclypsecl's Avatar
i have about 178 k
Old Apr 16, 2003 | 07:55 PM
Juki5536's Avatar
Thanks for the info, if only I knew how to fix that stuff. Closed loop control fault? What the... ? And I had 83K miles when the problems started, now 84K. Guess I gotta leave it at my mechanics for a day or two. Sigh, I'm gonna be lonely...
Old Apr 16, 2003 | 08:33 PM
sandman1098's Avatar
Are the EVAP Canister Purge Volume Control Valve and the Vent Control Valve the same part? Or are they different? If they are different, where are both parts located on the car? I know that they are behind the drivers side rear wheel...... I know the EVAP Canister is a black box....... Any help would be greatly appreciated.....
Old Apr 17, 2003 | 10:46 AM
MGokool's Avatar
*** Guys, I have a friend that works at Nissan, she told me for my trouble codes listed in earlier posts here, that first thing to check is the gas cap! She told me to clean the seal on the gas cap and on the neck of the tank and to reset the ecu...if it comes back on, then its a problem in the EVAP system, bring it in for service...HOWEVER, lastnight i put gas in the car so i cleaned the cap, put it back on and made sure it clicked several times...i didnt reset the ecu...on my way home about 20mins later, the engine light went off...i used to go to same-price-full-serve station and they always put the cap on...guessing it was loose this time...maybe this can be the same remedy for some of you!
Old Apr 17, 2003 | 12:16 PM
I had heard about the gas cap thing before, and I know its not my gas cap becaue mine is brand new...... lol
Old Apr 18, 2003 | 12:15 AM
eclypsecl's Avatar
no solution..anyone??
Old Apr 18, 2003 | 02:20 AM
Kanaka's Avatar
EVERYONE HAVING THIS PROBLEM READ THIS!!!
There is a recall on our 4th gens regarding the Evaporator Canister System. That is an emission problem so it is not limited by age of the car or mileage. You can call your local nissan dealer and tell them your VIN #. They will verify that your car has not been serviced for this problem. Your car can only get repaired for this problem once. Unfortunately my car already had this repair and I got the code again so I am S.O.L. But if your car has never had this repair it should be done by Nissan at no cost to you. Again, no limitation on mileage or age of the car, (but I believe it is limited to only 95-99's) but you can only get it done once per car.
Old Apr 18, 2003 | 07:35 AM
XXXL Cracker's Avatar
EVAP canister and valve are located behind the driver's side rear tire. You will see a black box with several hoses and wires coming from it.
I had these codes and I took off the canister and valve and cleaned the valve thoroughtly. This is the first I have heard of the recall. The valve will get stuck if it is dirty and due to us just coming out of winter, cars in snowy climates are probably dirty as hell underneath.
There are instructions on disassembly in the Haynes manual. It really is not too hard to do just takes a little time.
D
Old Apr 18, 2003 | 08:28 AM
hokiemax's Avatar
Originally posted by dlicari
ECAp canister and valve are located behind the driver's side rear tire. You will see a black box with several hoses and wires coming from it.
D
yo dave, so after you cleaned the evap system, did the engine light go off ?
Old Apr 18, 2003 | 09:10 AM
Yes. No more code
I just took the valve apart, cleaned it and made sure it was moving freely. I have also found if the gas cap is not put on tightly, the light will come on.
D
Old Apr 18, 2003 | 09:15 AM
dizman's Avatar
FYI ODB-II P1448
FYI
I've had a P1448 forever and just recently tried fixing it. And I just now had success.
The P1448 for a 97 Maxima is "Evap Canister Purge Flow Control Valve" Unlike most other Evap stuff this is located under the hood. It's just to the compartment side of the manifold. It used 2 12 MM nuts to secure it and has two ~ 1/2" hoses coming from it. It also has a connector with 6 pins/wires. Looking at the receptacle on the valve, you should have 30 ohms between the first and second and second and third pins and 60 ohms between the first and third pins on both (top and bottom)rows. I had an open between the second and third pins on the bottom row. I fixed this by removing the valve assembly and then removed the end (brown end) with the connector. (using 3 phillips screws)Be careful because there is a spring inside the assembly. I then placed a small dab of solder on the inside on the bad pin. Looks like ther was a cold solder joint.
Hopes this helps someone!
Old Apr 18, 2003 | 09:36 AM
I think it might actually help me... Im going to the dealership to get the part for my car.. I think that might be the part.... Thanks
Old Apr 18, 2003 | 12:43 PM
dizman's Avatar
OOP!! P1445 not P1448
Sorry, in my haste to reply I wrote down the wrong fault. Mp P code was 1445 not 1448. This relates to ECU code 10 08
Old Apr 18, 2003 | 04:55 PM
Kewl.... I just bought my new EVAP Canister Volume Control Valve, and when I was trying to put it on, One of the bolts that attaches the valve to the canister was stripped and wouldnt come out..... I may just have to buy a new EVAP canister tomorrow....
But when I get it done, I will be one happy ****
Thanks for the information....
Old Apr 18, 2003 | 07:09 PM
dizman's Avatar
Yeah when I was learing about this emissions crap I also tried to remove that valve and also had one bolt just keep twisting. That valve is the vent valve. I got the one bolt loose and rotated the valve and then sprayed with WD-40 and lossened it up, but it wasn't the problem. If you do that, be careful of the O-ring between the valve and canister
Old Apr 18, 2003 | 08:49 PM
Juki5536's Avatar
Re: EVERYONE HAVING THIS PROBLEM READ THIS!!!
Are you serious or are you joking? Either way I'm going to have a heart attack. I'll call Nissan tommorow! Nice! I have a '98.
Old Apr 19, 2003 | 02:26 AM
Kanaka's Avatar
Re: Re: EVERYONE HAVING THIS PROBLEM READ THIS!!!
I'm not joking. My friend is a mechanic at the local Infiniti dealership. He ran my VIN and it turns out the previous owner did have the fix done. If it wasn't done, he could have done it for free. He says that he has done cars as old as 96 recently and he said because it has to do with emissions there are no time limitations.
Old Apr 27, 2003 | 07:03 PM
Juki5536's Avatar
I called that place, and they said it was for 96's only.
Old Apr 27, 2003 | 07:05 PM
Juki5536's Avatar
I called my local Nissan dealer and they said the recall was for 96 Max's only. I'm a 98.
Old Apr 28, 2003 | 09:13 AM
WifesMax's Avatar
Stripped bolts
For those of you whose canister had stripped threads (which seems to be more than a few), I have a few questions...
1. How did you remove the valve?
2. Is the operation of the valve sensitive to both bolts being tight. In other words, could a less-than-tight seal due to a stripped bolt cause the leak?
Old Apr 28, 2003 | 10:25 AM
I had the stripped bolt problem, and I just spent the extra money to get new EVAP canister.....
Old Apr 28, 2003 | 01:33 PM
hokiemax's Avatar
ok so how much was the new EVAP canister?
Old Apr 28, 2003 | 02:54 PM
just under 70 bucks....
Max139617
Sep 29, 2015 06:44 PM
homeofbacon
Sep 23, 2015 07:17 PM
jchronis2552
Sep 21, 2015 05:52 AM
Steven Orozco
Sep 12, 2015 10:41 PM
dcam0326
Sep 7, 2015 07:26 AM
