Still getting 01 02 CEL code after swapping all coils..any ideas?
Old 04-12-2003, 08:20 PM
Kevin's Avatar
Still getting 02 01 CEL code after swapping all coils..any ideas?
EDIT: sorry I meant 02 01 Ignition Signal Circuit
This f*ckin thing is driving me crazy, ignition signal circuit code. All coils swapped and still having the problem. I checked the ECU wires that looks ok...any ideas?
Kevin is offline
Old 04-12-2003, 10:20 PM
Evil Administrator - "The Problem"
bill99gxe's Avatar
DTC 0102
Diagnostic Trouble Code 0102 points to a problem with the Mass Air Flow Sensor.
The MAFS is placed in the stream of intake air. It measures the intake flow rate by measuring a part of the entire intake flow. It consists of a thin film that is supplied with electric current from the Engine Control Module. The temperature of the hot film is controlled by the ECM a certain amount. The heat generated by the hot wire is reduced as the intake air flows around it. The more air, the greater the heat loss. Therefore, the ECM must supply more electric current to the hot film as air flow increases. This maintains the temperature of the hot film. The ECM detects the air flow by means of this current change.
This malfunction is detected when an out-of-range voltage is sent to the ECM. That voltage might be too high
or too low.
a) An excessively high voltage from the MAFS is sent when the engine is not running.
b) An excessively high voltage from the MAFS is sent under light load driving conditions.
Possible causes include...
- Harness or connectors (the sensor circuit is open or shorted.)
- Faulty MAFS
c) An excessively low voltage from the MAFS is sent when the engine is not running.
d) An excessively low voltage from the MAFS is sent under heavy load driving conditions.
- Intake air leaks
- Faulty MAFS
With DTC 0102 the ECM is supposed to switch into Fail Safe mode and limit engine speed to 2400 rpm.
bill99gxe is offline
Old 04-12-2003, 10:29 PM
Kevin's Avatar
Re: DTC 0102
Originally posted by bill99gxe
[/B]
made a mistake is 02 01
sorry.
Kevin is offline
Old 04-13-2003, 06:17 AM
njmaxseltd's Avatar
Kevin, on the main wire harness on the top right side of the engine you can find, wrapped up in black tape, a condensor. It has only one lead on it, it may be bad. The condensor taps onto the ignition signal to smooth things out.
njmaxseltd is offline
Old 04-13-2003, 08:30 AM
Kevin's Avatar
thanks I'll look at it today,
Would that effect things like the car shaking a lot in reverse? How easy/hard is it to replace that connector?
Kevin is offline
Old 04-16-2003, 09:28 PM
Kevin's Avatar
bump...what does that codensor harness do?
Kevin is offline
matts95max
05-20-2024 01:16 AM
iflexsteel
09-02-2015 08:04 AM
Quick Reply: Still getting 01 02 CEL code after swapping all coils..any ideas?
