AAHHH!! I bent a valae
AAHHH!! I bent a valve
jcy98maxse and I were racing tonight and in a botched one two shift I hit the fuel cutoff. Well when I let my engine wind down I heard a loud knocking that sped up or slowed down with the rpm. I popped the hood and listened to the valve cover and I beleive I bent a valve. The weird thing is I have the stock 6500rpm limiter and I know plenty of guys that take their cars to 7000rpm with a jwt ecu.
I am going to fix this myself but I would like your input as to where I can get inexpensive quality parts. Also while I have the head off what modding should I consider? Who knows I may have to replace the piston.....that would really frustrate me.
Re: AAHHH!! I bent a valae
I am going to fix this myself but I would like your input as to where I can get inexpensive quality parts. Also while I have the head off what modding should I consider? Who knows I may have to replace the piston.....that would really **** me off.
I hope you can get that fix relatively inexpensively and that it didn't cause too much engine damage.
u can get replacement head for $150... cheaper then getting it fixed i would bet...
If u have issues finding a head at this price i got one i'll sell for that..
cbr2@softhome.net
cbr2@softhome.net
Originally posted by Dave B
A rev limiter cannot slow down the momentum of a motor when it's misshifted.
Dave
Dave
I'll look into how much the cost to repair it is. cbr2, is the head used or new? What condition is it in?
Well I found the culprit. One of the butterfly valves on my MEVI came off and one of the screws holding the valve in place was sucked down the intake runner. It is either holding my valve open leaving a gap between my camshaft and the piston that pushes the valve so every time the lobe goes by it slaps the piston.
The other and much worse option is the screw held my valve open just long enough for my piston to slap the valve and bend it which would cause the same scenario as above to occur only with much more damage. I will find out tomorrow after work.
Who knows how much clearance is between the valve and the head when it opens? Hopefully not much.... I know its the size of the lobe but does anyone have an exact length?
my friend took his contour to the max and well, we heard the exact same thing you heard, we tried to drive it home, poof looked like all teh oiil burned out through the exhaust when the poor engine finally died... dont know if its the same thing that happend to you but if it is get a new engine....
DC_Juggernaut
Sep 28, 2015 04:07 PM
Hdnseek
Sep 9, 2015 05:55 AM
