To those with an uninstalled set of KYB dustboots laying around...
Old Apr 13, 2003 | 04:28 PM
Vyrus's Avatar
Could you please read me the part number off of the piece? It should be imprinted in the rubber right underneath the bumpstop.. says something to the effect of NA103 or NA108.
Thanks,
-Cyrus
Old Apr 13, 2003 | 07:05 PM
Vyrus's Avatar
Bump anyone please!!
-Cyrus
Old Apr 13, 2003 | 07:35 PM
Nick97SE's Avatar
IIRC, the part numbers are SB103 and SB108.
I ordered my boots from Tirerack. I ordered front boots from a '95 Mustang and rear boots from a '95 Miata. The part numbers are the same.
Hope this helps. Let me know if I can help you with anything else.
-Nick
Old Apr 13, 2003 | 07:38 PM
Vyrus's Avatar
-Nick
Thanks for the reply Nick! Mine are NA103 and NA108 so I'm would think they work fine. The only problem is that the rear boots' bumpstop seems to have a little too small of a hole to fit the strut. The opening is big but it gets smaller.
Thanks,
-Cyrus
Old Apr 13, 2003 | 07:42 PM
Nick97SE's Avatar
Are they KYB?
-Nick
Old Apr 13, 2003 | 07:44 PM
Vyrus's Avatar
Are they KYB?
-Nick
Yes. I'll take a picture and post them later today. By the way the spring wrap you recommended worked miracles, not a creak from the springs all day.
-Cyrus
Old Apr 13, 2003 | 08:07 PM
Vyrus's Avatar
Pic...
Notice how there is a smaller ring within the bumpstop? That leads me to believe they will not fit a Maxima. I'm pretty sure the strut's shaft is larger than that hole.
-Cyrus
Old Apr 13, 2003 | 08:36 PM
Ramius83
Just drill it out to the required size......
Old Apr 13, 2003 | 11:14 PM
NYCe MaXiMa's Avatar
where did everyone buy their KYB dustboots from?
where is the better deal?
Old Apr 14, 2003 | 06:16 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: Pic...
-Cyrus
That is how mine looked. It slides on top of the piston shaft just fine. Mine looked exactly like that and it was the right part.
Old Apr 14, 2003 | 06:19 AM
phenryiv1's Avatar
Mod her. Ate her.
I go tmine from advanced auto. I posted the part numbers and the way to order them just a few days ago. I will post a link to the thread in a few minutes. Mine were boxed as "TRW" brand parts, but I compared them to the KYBs at the lowering meet and they were 100% identical right down to the stampings. They are just repackaged. Actually, it looked like KYB buys TRW parts and repackages them as KYB. Either way, they are identical.
Old Apr 14, 2003 | 06:28 AM
phenryiv1's Avatar
Mod her. Ate her.
Here is the link:
http://forums.maxima.org/showthread....&highlight=TRW
Old Apr 14, 2003 | 12:46 PM
Vyrus's Avatar
I bought mine brand new in the For Sale section. You're not going to save more than $5 that way, so you might as well order them from TireRack.com.
Patrick thanks for the information, it now seems like they will fit. I'm going to try installing them today.
Thanks again,
-Cyrus
Old Apr 14, 2003 | 02:58 PM
Nismo3112's Avatar
Custom User Title
off the subject but..
Im getting KYB's with sprints soon, what are bumpstops, and dustboots, and what parts do i need to replace when intsalling??
stock suspension has ~39k on them
Old Apr 15, 2003 | 06:58 AM
phenryiv1's Avatar
Mod her. Ate her.
Not trying to be a smart@$$, but this has been covered a dozen times in the last 2 weeks. Just page-back n the 4th gen forum and you will find tons of info.
The quick version- I replaced my strut bearings and bustboots @ 77K. That was it. You can spend hundreds of dollars to be sure that all is well, or you can risk re-using the old stuff. I would do the bearings and dustboots @ 39K. All of your rubber parts are most likely in good shape.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
