Cyl 4 misfire
Old Apr 13, 2003 | 11:23 PM
blackmxma's Avatar
Cyl 4 misfire
yeah, pulled the codes from the ecu cuz engine was really runnin rough, and along with my rear o2 sensor code (which I know is bad) I got 0605? I think, well anyways it was detecting a misfire in cylander 4. I just pulled it late tonight so I havn't had a chance to inspect plugs yet, but what is the most common reason for misfire and what should I check or do to fix it. thanks.
Old Apr 14, 2003 | 04:55 AM
fisher01's Avatar
Re: Cyl 4 misfire
Cylinder coil.
Old Apr 14, 2003 | 11:39 AM
msmokey3's Avatar
yeh i just pulled 2 codes from mine one was 0605 and the other 0903 which is the EVAP canister vent control valve. anyone have any idea how much it would cost to fix these two problems or if i even have to?
Old Apr 14, 2003 | 11:45 AM
FLO_BOY's Avatar
IF 0605 is a cyl. 4 misfire, then I suggest the following:
1) swap cyl. 4 coil pack with another cylinder...
2) see what happens.
if the code moves to the swapped coil pack, then you have a bad coil pack.
if the codes stays on the cylinder, then you probably have a bad plug.
I wouldn't worry about the EVAP code unless it happens after you've
fixed the misfire issue...I know I've had the EVAP code before, fixed
other issue, and never received EVAP again.
odds are the pack is bad...
FLO_BOY
Old Apr 14, 2003 | 01:01 PM
blackmxma's Avatar
great thanks. a little off topic, but I started this thread dammit, I'm also getting 0902 now which is rear 02 heater or somethin and I don't even know where that is or what it does besides monitoring heat. how can I check that thing
Old Apr 14, 2003 | 01:20 PM
FLO_BOY's Avatar
that's rear heated O2 sensor...not sure how to check it, but
sometimes the O2 sensor CEL goes off because you went on a high-speed
run, and the O2 sensors couldn't handle all of the pollution coming
out of your exhaust.
So, I would just reset it for now, and if the CEL comes on again,
then I would look into replacing it...
FLO_BOY
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
