wheel Quest.
Old Apr 14, 2003 | 09:13 AM
niksal's Avatar
wheel Quest.
I got 17x7 rims for a 99 max what wheel size ruber should i use? Also my rims came with bf goodrich g-force twa-2 205/40zr 17 should i use these?
Old Apr 14, 2003 | 09:22 AM
phenryiv1's Avatar
Mod her. Ate her.
Re: wheel Quest.
Most likely they are a little small for use on the max, even w/ a drop. If they are in good shape you should be able to sell them on eBay or a honad board for a fair price...
Old Apr 14, 2003 | 09:24 AM
abstrakt79's Avatar
you can use those tires if you want...it's your choice. a lot ofm people w/17s run 235/45s...it all depends on how much sidewall you want. also, if your going to be racing then you want harder tires(z-rated)...if not then h-rated tires will be fine. again, it's about what prefer...
Old Apr 14, 2003 | 05:42 PM
GMT_MAX's Avatar
re 235s: Probably shouldn't be running 235s on a wheel that's only 7" wide.
You can do some tire size calculations here: http://members.aol.com/agspeed/tiresize.htm
GMT
PS- that was pulled from the FAQ sticky in this forum. Read 'em!
Old Apr 14, 2003 | 05:45 PM
99Maxima5sp's Avatar
GMT
you can run them fine...just like you can run 225s on the Stock SE Max's rim..235s fit like a charm on a 7' wide wheel...
eric
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
