brake line replacement...what size flare-nut wrench?
Old Apr 16, 2003 | 02:36 PM
amb4081's Avatar
Hey everyone. I am planning on installing the Goodridge break lines Friday. I was reading through the write-up in the Haynes manual. It told me I would need a flare-nut wrench. What size do I need? Thanks.
Aaron
Old Apr 17, 2003 | 08:48 AM
amb4081's Avatar
Re: brake line replacement...what size flare-nut wrench?
BUMP
Aaron
Old Apr 17, 2003 | 08:57 AM
ejj's Avatar
ejj
I'm 99% sure its 10mm
Old Apr 17, 2003 | 09:01 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Originally posted by ejj
10mm
Old Apr 17, 2003 | 09:03 AM
redmaxpa007's Avatar
i SeE what you did therE
you can remove about 45% of the car with a 10mm...
Old Apr 17, 2003 | 09:04 AM
ejj's Avatar
ejj
But you really need a flare wrench for the fittings on the brake lines. Otherwise you'll strip 'em.
Old Apr 17, 2003 | 09:05 AM
xHypex's Avatar
Agreed 10mm flare nut wrench is what you want. Vise grips are good just in case.
-hype
Old Apr 17, 2003 | 09:07 AM
-hype
and a big sledge hammer too....
Old Apr 17, 2003 | 09:10 AM
xHypex's Avatar
sledge hammer ....?
Old Apr 17, 2003 | 09:19 AM
sledge hammer ....?
when you get mad and you strip the nut and you mess somthing up.. you take the sledge hammer and... well.. you get the picture..
Old Apr 17, 2003 | 09:28 AM
ejj's Avatar
ejj
I resort to drinking lots of beer when things don't go well.
Old Apr 17, 2003 | 09:31 AM
bill99gxe's Avatar
Grab your wallet, as a Craftsman 10mm flare wrench is $14.
I bought one last week after stripping a bleeder screw.
Do yourself a favor and buy the 5-piece metric flare wrench set for $25 so you don't feel so screwed over.
Old Apr 17, 2003 | 09:48 AM
xHypex's Avatar
That's a good idea, but it sucks that you rarely use flare nut wrenches. I got my 10mm flare nut wrench for about $11.
-hype
Old Apr 17, 2003 | 10:02 AM
amb4081's Avatar
-hype
Ok. Thanks everyone!!
I'm hoping all goes well. Do I need to pre-spray any PB blaster on the old break line connections or will it not be too corroded? Thanks again.
Old Apr 17, 2003 | 10:45 AM
ejj's Avatar
ejj
Couldn't hurt.
Old Apr 17, 2003 | 11:27 AM
amb4081's Avatar
Will I have this much trouble doing the lines changeout? Have the majority of you run into problems during the installation? I'm also not real sure what time frame to expect this to take? How long did it take you guys (gals if applicable)? I have never done brake line replacement, just rotors, pads, etc.
Old Apr 17, 2003 | 11:29 AM
ejj's Avatar
ejj
I didn't have any problems. I would guess it would take about an hour to change the lines, and then you need to bleed the system. Figure 2 hours tops.
Old Apr 17, 2003 | 04:12 PM
amb4081's Avatar
Thanks!
Thank you very much everyone. I appreciate all of your help. I wouldn't have been able to do any of these mods myself without the advice and experience of everyone here. Thanks.
Aaron
PS- I'll let you know how the install goes!
Old Apr 18, 2003 | 09:37 AM
amb4081's Avatar
brake fluid question
I am currently changing the lines out right now. I will check back in a few minutes for a response. Here is my question:
I have new brake fluid that I am putting in when I flush the system. Should I let all of the old fluid drain out when changing the hoses so that ALL NEW fluid will be present? Thanks
Aaron
Old Apr 18, 2003 | 09:40 AM
ejj's Avatar
ejj
Re: brake fluid question
Aaron
It won't all drain out if you let it sit (well, it may but it would take a really long time).
I just keep bleeding the system until the fluid that's coming out looks just as clean as the fluid you're putting in.
Old Apr 18, 2003 | 09:47 AM
amb4081's Avatar
Re: Re: brake fluid question
Thanks very much. I'll keep you updated.
Old Apr 18, 2003 | 11:16 AM
XXXL Cracker's Avatar
I resort to Tourett's Syndrome " You no good dirty, rotten m@#@#@focker!!!!!!!!!!!!!!!!!!!!!!!!!!!"
Then I go back to work
Old Apr 18, 2003 | 11:55 AM
ejj's Avatar
ejj
I find the heavy drinking reduces the need for such profanity, because, well, aftre a while you just won't give a ****.
Old Apr 18, 2003 | 11:58 AM
95maxmadman's Avatar
Is it a big p.i.t.a. to bleed the brakes w/out speedbleeders?
Is it a 2 man job?
Old Apr 18, 2003 | 12:00 PM
ejj's Avatar
ejj
Is it a 2 man job?
Without speedbleeders or a vacuum system its a two man job. Its not difficult though.
Old Apr 18, 2003 | 03:07 PM
amb4081's Avatar
Ok. I have a problem . I got all of the lines on ok. Woo hoo!! My brother and I bled each line.
He would slowly depress the brake pedal. Once fully depressed, I opened the bleeder valve and saw the bubbles in the jar that had a little brake fluid in it. Just like the manual says. Anyway, I did this procedure for each wheel. For each wheel, this was done until only fluid was coming out of the bleeder valve.
However, My brakes are extremely spongy. If I only gradually depress the pedal, there is little or no resistance and the pedal hits the floor. If I slam on the brakes, there is a delay before the pedal feels stiff. Does this sound like I still have air in the lines? Please help!!
Aaron
PS- I did look under the car and there is no sign of leaking fluid anywhere.
Old Apr 18, 2003 | 03:10 PM
Jeff92se's Avatar
I'm needing a caw
Pressure bleeder. One man operation. No worries about empting the master cylinder accidently(and starting all over again)
http://forums.maxima.org/showthread....essure+bleeder
Old Apr 18, 2003 | 04:03 PM
ejj's Avatar
ejj
Yup. I usually have to repeat the bleading procedure at least twice, if not more.
Old Apr 18, 2003 | 04:34 PM
amb4081's Avatar
Thanks ejj and everyone else. I appreciate all the replies you've posted. I'll get the car out of the garage again tomorrow, jack it up, and go through the bleeding procedure a few more times. And I will post an update following that. Thanks.
Aaron
TO BE CONTINUED...
Old Apr 21, 2003 | 07:09 AM
amb4081's Avatar
Finally finished....
Well, I finally finished the brake job Saturday afternoon. I re-bled all four brakes again. The front two were fine. However, the rear two brakes still had air in the lines. It must have been upstream a little bit and I didn't get it all out the first time I bled the brakes.
But now, the sponginess is gone. The pedal feels a little firmer and stops well. Not too bad of a mod. Normally I would not have done SS brake lines, but they came with the brake package I bought. Thanks for everyone's help!
Aaron
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
05RLS2
Sep 27, 2015 09:24 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Johnny9595
Sep 16, 2015 07:20 PM
