Does Y-pipe change the sound of a stock exhaust system!!
Old Jan 19, 2001 | 02:45 PM
infinitiblast's Avatar
When I get my 1996 Se 5spd maxima I want to have ready in my garage to put on a CAI, Y-PIPE. My question is does the y-pipe change the sound of the stock exhaust.
Old Jan 19, 2001 | 02:47 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
yes it will...
the jet-hot coating will yield more noise than the SS version...to avoid the increase in noise...use header wrap on the Y....
Old Jan 19, 2001 | 02:51 PM
vbxmaxima's Avatar
It really depends on which ypipe you get.
The Cattman stainless (which I have) hardly makes any sound but is more expensive.
The Stillen's makes a lot more. Although I hear that the new stillen 2 peice design is a little quieter.
Take a look here:
http://vbxmaxima.8m.com/ypipe.html
You may find some other info of use.
Old Jan 19, 2001 | 02:58 PM
Jeff92se's Avatar
I'm needing a caw
Yes it will. But not for the reasons that most people think. The type of material doesn't matter. ss, Jet Hot, mild steel, aluminized steel. Whatever.
The single most important thing about the Y pipe for noise is the design of the FLEX PIPE. If it's unlined(like the old cattman Jet-Hot ones were and like the Stillen ones I think) it will be noisy. If you get one w/ a better quality flex section that is LINED, it will be VERY quiet.
I spent alot of $, to find the above out the hard way. Trust me on this. For which every Y you decide to get, you #1 question to the vendor should be, "Do you use a lined flex section or not?".
Old Jan 19, 2001 | 07:14 PM
bmfjeep's Avatar
Flex question
I asked 3 major exhaust distributors (vendors) if they ever heard of a lined flex connector and they said no. They said the flex joint with the multi layered stainless braided wire with the stainless corrugated liner is the only flex joint on the market, they said the number of layers of braided wire varies. They said there are of course several manufacturers of them, some good and some not so good. We actually get ours from Canada, they are the best quality we have found. If there is a lined flex joint send the info and we will check it out. They said the biggest difference is how much space is in between the braided stainless wire and the corrugated liner, too much and it vibrates.
regards
Dallas Warpspeedperformance
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
stromm
Aug 27, 2015 04:13 PM
maxinout93
Aug 20, 2015 02:17 AM
wyobbagy
Aug 15, 2015 02:28 PM
