links to how to rewire your corner?
Old Apr 18, 2003 | 10:57 AM
taeMAX97's Avatar
can someone help me find or tell me how to make your corner lamp brighter?
Old Apr 18, 2003 | 11:06 AM
ORBRIT's Avatar
Re: links to how to rewire your corner?
If you have a 97, you don't need to rewire anything - you just need to reverse the 1157 bulb in your clearnace lights so it utilizes the brighter higher wattage filament.
remove the clearance light, remove the bulb, snip off the upper nub (closest to the glass), put the bulb back in, lining up the lower nub with the guide for the upper nub on the socket.
If it's a loose fit, use some electrical tape to make it a snug fit.
Old Apr 18, 2003 | 11:13 AM
taeMAX97's Avatar
hmm... yes i have 97 but im stupid j/k..
can you be more specific? and that would make my corner bulb brighter right? cause even though i have same bulb for corner lamp and bumper, bumper light looks alot brighter than the corner.
thanks,
Tae
Old Apr 18, 2003 | 11:21 AM
ORBRIT's Avatar
thanks,
Tae
bumper light? you mean the one next to the turn signal? That's a 194 bulb, the clearance light (corner light) next to the headlight is a 1157 dual filament bulb.
Before (the upper one is the corner "clearance light" and the lower one is the one you're calling the bumper light)
After
Old Apr 18, 2003 | 11:28 AM
ORBRIT's Avatar
Then the bumper light looks too yellow, so...
Old Apr 18, 2003 | 11:48 AM
taeMAX97's Avatar
i was talkin about corner lamp right next to headlight. wow ur cornor light looked bright before you upgraded it. what kind of bulb are/were you running?
thanks,
Tae
Old Apr 18, 2003 | 11:49 AM
95maxmadman's Avatar
Can this be done on a '95?
Old Apr 18, 2003 | 05:08 PM
ORBRIT's Avatar
I think on a 95 you have to rewire the light some how as it uses the high wattage filament when you use your turn signal.
Old Apr 18, 2003 | 05:14 PM
ORBRIT's Avatar
thanks,
Tae
OK, now I'm confused about which light you're talking about.
The clearance light mod (reversing the bulb to use the brighter filament) is for the "corner light" next to the headlight. The upper light in my pictures.
The first picture was taken with APC superwhite 1157 bulb in the correct way. You can see how dim it was, because the rest of the picture is so dark - I could barely see in my garage.
The next picture was after I reversed the bulb to fit the other way.
It lights up the entire garage!
But then my bumper lights looked really yellow in comparison.
the 3rd picture is after I changed the bumper lights to APC superwhite 194 bulbs.
Here's a head on view of my car at night.
Old Apr 18, 2003 | 05:25 PM
danimsta's Avatar
if u wanna learn how to do it on a 95...
go to my site
www.danimsta.com
click on HOW to
then clickk brighter corner mod
lemme know if u need any help
theres also pictures to show u what to do
Old Apr 18, 2003 | 10:12 PM
95GreekMaxSE's Avatar
97 doesnt need to be modified for brighter bulbs but needs to be turned to use higher filament. Same with 95, just turn bulb to use high filamment. The 96 was the last year the corner got brighter for turns.
Old Apr 18, 2003 | 10:22 PM
ORBRIT's Avatar
I have a question for you 95-96 guys who have done the bulb reversal.
When you use your turn signal, does your clearance light go dim?
Old Apr 19, 2003 | 08:00 AM
gtr_rider's Avatar
192.168.1.1
How to rewire your Corners 97-99
How to Rewire your Corners 95-96 Hope you dont mind ORBIT
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
rbaker100
Sep 25, 2015 07:52 PM
Blkkn8
Sep 22, 2015 06:37 PM
