19inch rims and lowering
i am looking to get some 19inch Konig Verdicts and lower my car.. i would like to know what is a good size tire and a good lowering combo. i have a 98 gle and i knida like the ride. i have a FSTB and RSB. i want to know how much is gonna change in my ride and how it will look. i have heard about KYB AGX's. how good are they?? What will lowering my car entail? What should i buy? hopefully you guys can help me out. thanks.
evan
evan
Well I don't have 19's but I am also in the same position as you. I have research a lot, since I want some big wheels but I don't want my car to ride like if I had no suspension. I was considering 18's but 19's just look better. N e the recommended size tires depends on the size of the rims you want. I am getting 19x8 the recommended size is 235/35/19 I am thinking ok getting 245/35/19 so that I can get a tire just a little bigger. That may help keep the side smooth. But I am still deciding on the tires. I may end up buying 235/35/19 cuz they are cheaper.
For springs. with out doubt I am going to buy H&R. H&R springs are the closest ones to the stock SE spring and they will only lower the car 1.3-1.5". That will look perfect with 19's
For struts I will probably buy Tokico llumina. My friend has those and they really perform better that KYB AGX. KYB AGX are also great and cheaper but I want a softer ride so Tokico llumina will do for me.
I hope this may give you some ideas on what to get. If you want 19's and don't wanna lose the comfort of your car you may go with these. I have been researching about all these for like 6 months and next month I will finally have 19's.
19" rims
get 245/35/19 for 19x8 or 19x8.5
go with 8.5 and 245/35 for best looks and ride. remember, more rubber and wider is better! ask any girl!
the road noise will increase on 19 and you will feel it but it's not bad. same as 18 or 17" just looks a whole lot better! and bling bling rims are the best!
Re: 19inch rims and lowering
evan
evan
Re: Re: 19inch rims and lowering
Originally posted by Ravq
Progress/AGX w/ 19x8.5 ADRs wrapped in 235/35 (sig pic). I also recommend the 245/35s. I chose the 235/35 to stay truer to speed.
wow, those rims look too sweet on your car!
RAV Q how is your ride?
Originally posted by I H8 COPS
You sound like a noob
Anyway, those numbers stand for wheel width in mm I believe
http://www.tirerack.com/tires/tiretech/general/size.htm
For example, my setup
18x7.5 225/40/18
Rim: 18 inch diameter rim, 7.5 inches wide
Tire: 225 mm overall width, section height is 40% of 225, and fits on an 18 inch diameter rim
Stock SE rims are 16x6.5 I believe
Also, a long discussion on lowering and stiffness:
http://forums.maxima.org/showthread.php?threadid=205178
Re: Re: Re: Re: Re: 19inch rims and lowering
Originally posted by Bull Jive
245/35/20. 255's would have been a tight squeeze.
I think if ya check up on it, 245/35-19 is closer to the stock diameter
I went with 245/35-19s ride isnt like stock no doubt haha
I do have rubbing problems because I had to run spacers to clear my BBs- try to stay with an offset 38-45mm andhopefully you wont have rubbing problems
my problem is also the S-02 tires- they are the widest 245s you'll run into because of their rim protector bar and super wide shoulder
Re: Re: Re: Re: Re: Re: 19inch rims and lowering
not tires springs. i am looking at getting some soon u know springs and struts. also what else am i gonna need to install these. i hope to have them on soon
I have 17's and after installing my KYB/AGX's and H&R's I think my ride is kind of stiff now. I have tried different settings but the one that works for me as far a comfort is 1 in front and 2 in back, and it is still pretty stiff. The AGX's feel a tad smoother now after having them in for a few weeks, my kids also agree, but maybe this is due to us getting used to it. I will try motivational mounts later to make it a little less harsh for the little ones.
I will hopefully be getting 19s within a month or two. I would really like to get 255, but would there be any rubbing? Also, I've heard that the lower the aspect ratio the worse the ride, and more likely to bend the wheel. I would like to get 255/30, but would the ride be really bad, and would the wheel get bent over a small bump? If I were to get 255 how wide would the wheel width have to be? How much of a drop should I get front/back that would still have decent clearence? I would like to get a Stillen kit later on once I get more money. Thanks for everyones help.
Also, it's hard lowering a car without having a stiff ride. If the ride wasn't stiff, you suspension would absorb the bump and your car's underside would slam into the concrete. I'd actually say to turn up your shocks, another guy with H&Rs said his optimum settings were near full stiff. Leaving your shocks on a low setting is like riding around with blown shocks, they won't do much damping, and the ride will be bouncy.
Originally posted by drewm
I don't think motivational mounts will help unless your car is bouncing on the rear bumpstops. Generally mine only did that with people in the back and shock settings that weren't stiff enough.
does 19in rims rub at all? what kind of tires should i get (size). and to lower the car what is the best. i was looking a maxtuning and they are selling the rims for 1725.00 + shipping. i would like to know if thry will rub!!
well this is what i need to know. can someone please fill me in.
Additional info on wheel offsets:
http://www.usacomp.com/Offset.htm
Any rubbing at all?
What do you all think about 20x9,would it fit?
HArry.
Originally posted by big h
Hi Bull,
Any rubbing at all?
HArry.
Hi Bull,
Any rubbing at all?
HArry.
i saw it on a max in a mall parking lot the guy wasn't around for me to ask him what was his offset.
i even checked the front tire and he had 225/35/19
the car looked really good and the rear tire looked very wide.
Hi Bull,
Any rubbing at all?
HArry.
Hi Bull,
Any rubbing at all?
HArry.
hey. na, no rubbing at all....that is after i got my back fenders rolled
Originally posted by illville
Bull Jive I was thinking of getting 20's using stock struts and springs how is the drive? Any suggestions would be helpful.
truthfully, the ride isn't bad at all, and if it is odd at first you will get used to it very quickly. although, if you're gonna get 20's you might want to look into a slight drop. i have H&R's and KYB AGX's. you will most likely have to get the lip under your back fenders rolled up, but it's worth it in my opinion! if you have any other questions feel free to pm me. good luck Jim
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
