I need 2 odd light bulb numbers please!
Old Apr 19, 2003 | 07:52 AM
bb0ys's Avatar
My hazard button light is out and so is the light bulb in the green circle around the ignition. Could someone tell me what type of bulbs (part #) I need to replace these with? Also, How do I get to the green ring around the ignition? I'm not sure where to pull things apart.
Thanks!
Old Apr 19, 2003 | 09:03 AM
Bull Jive's Avatar
Re: I need 2 odd light bulb numbers please!
i don't know the number of the parts but i do know that the bulbs are very very tiny.
Old Apr 19, 2003 | 09:43 AM
95GreekMaxSE's Avatar
radioshack part number 207-1092.. pm me or reply for more info on replacing
Old Apr 19, 2003 | 06:04 PM
bb0ys's Avatar
more help
I need a little more help. I had the dash/console apart for cleaning and I couldn't figure out how to remove the hazard lights botton to get to the bulb. I also did a search at radio shack.com for 207-1092 and couldn't find anything. Also, If anyone has a how-to on getting at the light behind the ignition switch that would be great. thanks!
Old Apr 19, 2003 | 06:27 PM
maximizeditalia's Avatar
Re: more help
[Hey guys i am new to this generation my 3rd gen was totalled now i have a 1997 just got it today and already did customizing. Anyways to get the hazards out that part is connected to the vent part held in only by clips. Do not be afraid of breaking it i was but it came out. i removed this when i was installing my radio. Good luck
Old Apr 19, 2003 | 08:08 PM
bb0ys's Avatar
Yes
I removed the vents and detached the wires from the hazard switch, defroster switch, and clock. However, i can not figure out how to get inside the hazard switch in order to change the bulb. anyone know?
Old Apr 19, 2003 | 11:24 PM
after taking out the vent pieve, you should have access to the back of the hazard light unit itself. on one side on the back, you will notice a clip that you can push in, push that in while pusing the hazard light unit out foward...once out of the vent piece, disassamble the unit.. Observe it and you will see how to take it apart. Once you do, the bulb is riight there with a red gel cover on it. Good luck
Old Apr 20, 2003 | 02:19 AM
danimsta's Avatar
for the ring around the ignition
take off the bottom and top of steering columb.. should be 4 screws.. then just pull off the ring...
its not to hard
Old Apr 20, 2003 | 06:45 AM
bb0ys's Avatar
thanks!
Do both of these use the exact same bulb?
Old Apr 20, 2003 | 08:55 AM
i suggest taking both bulbs to radio shack and do a size comparison..u should be fine.. good luck
mvm062
Nov 30, 2020 09:00 AM
iflexsteel
Sep 15, 2015 03:37 AM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
