Front rotor removal question....
Old Apr 19, 2003 | 09:39 AM
Raw_Toast's Avatar
Basically thats it, is there a trick to getting the front rotor off the car?
Old Apr 19, 2003 | 09:56 AM
KFL's Avatar
KFL
It will be stuck on pretty tight if its stock. There are two I believe threads in the rotor, find 2 bolts or 1 that fit into the thread and drive them in with a socket, this will make the rotor pop off the hub.
Did my friends max rotors 3weeks ago, ss brake lines, pads yadda.
Old Apr 19, 2003 | 10:28 AM
Geophrum's Avatar
http://www.motorvate.ca/
has a good write up for front rotor work
I just hit the back of the rotor with a small 2x4 (so i dont actually hit the rotor)and a hammer then turned the rotor and hit it again and it poped right off
Old Apr 19, 2003 | 10:30 AM
deezo's Avatar
Re: Front rotor removal question....
Rubber mallet and of course, remove the caliper. It should fall right off.
Matt93SE
May 24, 2019 02:58 PM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
RealityCheck
Aug 5, 2015 06:18 AM
