put stock springs back on
Old Apr 21, 2003 | 10:15 AM
Cumalot's Avatar
Today I took off the Eibach springs and put back the stock springs back on. I can't handle the stiff ride anymore. I also put the stock front struts(from a friend's I30)back on. I still have the rear AGXs though. The ride is much smoother, but of course the dreaded wheel gap is back. It's ok though because it's not that bad with the stock sawblades on. I know I will need an alignment. Could I get an alignment right away? I asked this because I know if I put aftermarket springs on, I have to wait two weeks for them to settle a bit before an alignment.
EDIT: I thought the front driver side AGX strut was blown, but I just tested it by pushing down on it and it came back up. So I guess it's not blown. Hm...now I think it has to be the strut bearings. I don't hear any noise anymore. When I still had the Eibach and front AGXs on, I would hear a weird popping kind of sound when I turn the wheel. Now I don't hear it anymore.
Old Apr 21, 2003 | 10:22 AM
Vyrus's Avatar
You can get one right away, the reason people say to wait 2 weeks is so that the problems will be exaggerated. But if you have a good alignment shop they will be able to catch any problems now.
BTW, it's becoming obvious that you are old now.
-Cyrus
Old Apr 21, 2003 | 10:30 AM
njmaxseltd's Avatar
Get the new AGX's in up front first! Otherwise your going to align it twice. Once now and once when the new AGXs go in.
BTW - Stock SE springs + AGX = Awsome ride!
Old Apr 21, 2003 | 10:36 AM
Cumalot's Avatar
Vyrus: old now? I been old for quite sometime.
njmaxseltd: I just took out the front AGXs that I had on. I thought the driver side was blown, but I guess after I tested it, it wasn't blown after all. I'm going to just stick with the stock struts. If I get an alignment now and put in stock struts back on the rear at a later time, I don't need to do another alignment right?
Old Apr 21, 2003 | 11:12 AM
Vyrus's Avatar
It was never so obvious.
And if you put the rear stock struts back on later you shouldn't need an alignment, but there is always the chance that you will.
-Cyrus
Old Apr 21, 2003 | 12:28 PM
goldmax's Avatar
Better ride than stock springs and struts????
Old Apr 21, 2003 | 12:29 PM
Vyrus's Avatar
Better as in better handling, yes. Better as in smoother ride, no.
-Cyrus
Old Apr 21, 2003 | 12:32 PM
Maxima95Tuner
Would you be willing to sell yer eibachs? Im looking to get some, and I have the stock sawblades on too.
If you wanna sell them, how much, what kind of condition are they in, and how long ago did you get them?
Old Apr 21, 2003 | 12:40 PM
goldmax's Avatar
-Cyrus
Thanks!
Old Apr 21, 2003 | 05:00 PM
Cumalot's Avatar
Yes, I'm going to sell the Eibachs. Stay tuned for a thread in the 4th gen classified.
Old Apr 21, 2003 | 05:35 PM
ny96max's Avatar
any pics of the car back to stock height?
Ant
Old Apr 21, 2003 | 06:30 PM
Cumalot's Avatar
Ant
Too hideous to show.
Old Apr 21, 2003 | 06:40 PM
Vyrus's Avatar
You would have to turn the camera vertical if you want to get it all in.
-Cyrus
Old Apr 21, 2003 | 06:43 PM
Cumalot's Avatar
Does anyone know for sure if the front AGXs are fine? Since I tested them by pressing down on them and they came back up. Does this mean they are fine? If that's the case, I might just put them back on and see how they ride with the stock SE springs. Tks.
Old Apr 21, 2003 | 07:55 PM
metallic97gxe's Avatar
Master Will
Old Apr 21, 2003 | 07:56 PM
Sprint's Avatar
so when you changing back to eibachs?
Old Apr 21, 2003 | 08:41 PM
Cumalot's Avatar
Hopefully I can sell them before I change my mind.
Old Apr 21, 2003 | 08:57 PM
maximum810's Avatar
When upgrading the shocks and springs, is it necessary to have the camber readjusted with a kit or so?
Old Apr 22, 2003 | 06:27 AM
Cumalot's Avatar
Old Apr 22, 2003 | 06:32 AM
njmaxseltd's Avatar
They should be nice and firm to push down and come back up nice and slow. I'm sure there good, toss them on with the stock springs. The ride is totally awsome.
Old Apr 22, 2003 | 10:09 AM
Cumalot's Avatar
Yup, that's how they are. Guess they are still good, so I guess I'm going to keep them.
Old Apr 22, 2003 | 10:12 AM
Cumalot's Avatar
I changed my mind about keeping the stock springs on. I decided to get a set of H&R springs and combine them with the AGXs that I have now. I almost forgot that my sister is going to give me her set of 17" Tantrums from her '00 Accord V6. So if I slap the Tantrums with the stock springs, it would look even more hideous than it does now with the sawblades.
Btw, yes I do tend to change my mind.
Old Apr 22, 2003 | 10:14 AM
Sprint's Avatar
wait till you try to go around a couple corners you use to go around, it doesn't matter if you sold them or not. You will buy another set.
Old Apr 22, 2003 | 10:20 AM
Cumalot's Avatar
I guess you are trying to say the H&R doesn't handle as well as the Eibach? I don't really care for handling to be honest. I usually take corners real slow anyway.
Old Apr 22, 2003 | 10:25 AM
Sprint's Avatar
oooooooooooohhhhhhhh.. you are on H&R's.. i thought youwere on stock springs
H&R's on AGX's are going to be harsher than Eibachs and AGX's..
from what i have learned from the Suspension Master Tom.. H&R's are better suited with a Strut/Shock of Tokico Blues..
Hope the H&R's and AGX's work out for you though.
i think its.. Soft Spring goes with Soft Strut/Shock. Stiff Strut goes with Stiff Strut/Shock.. so:
H&R's goes with Tockico and Eibach's go with AGX's.
I had the H&R's and Tockico combination and the ride was PERFECT.
Old Apr 22, 2003 | 10:27 AM
mzmtg's Avatar
Minister of Silly Walks
I'm takin my Eibachs off in a couple of weeks, stay tuned
Old Apr 22, 2003 | 10:37 AM
sidewinder740's Avatar
Are you going back to Sprints or stock springs?
Old Apr 22, 2003 | 10:41 AM
Sprint's Avatar
Ha
Old Apr 22, 2003 | 12:05 PM
Cumalot's Avatar
I'm having second thoughts on the H&R springs idea. I just checked out this thread and the news isn't too good: http://forums.maxima.org/showthread....hreadid=199714
Crap...I'm not sure what to do.
Old Apr 22, 2003 | 02:24 PM
Yeah dude--if you drop your car with any type of lowering spring your ride will suffer. The H&R's do ride a good bit better than all the others though.
Old Apr 22, 2003 | 02:54 PM
MaxWolf's Avatar
This is my work in progress, (that will be complete in less than a month)... to have a nice comfortable riding...decently dropped, max.
Spring - H&R
Strut (front) - Tokico blue
Shock (back) - Illumina's (adjustible, not too expensive) or GR2's
Rear Strut Mount's - Motivational (comfortable)
...this is what my research has brought me for a comfortable, lowered, lil sporty (if you want it)...ride
Old Apr 22, 2003 | 04:43 PM
Cumalot's Avatar
Hm...
Old Apr 22, 2003 | 05:31 PM
BOZOnPJs's Avatar
threads like these make me happy to be stock. CF dash kit instead of springs for next mod.
Old Apr 22, 2003 | 09:03 PM
Cumalot's Avatar
Well, I just put the front AGX struts back on. I still have the stock springs on though. I think I'm going to just leave it as that. The ride is very good. Btw, I have the front and rear at 1. Going to get an alignment tomorrow.
Old Apr 22, 2003 | 09:08 PM
How does the stock spring/AGX setup compare to your Eibach/AGX setup in terms of ride quality--night and day right?
Old Apr 22, 2003 | 09:14 PM
Cumalot's Avatar
Big difference! There's no comparison IMO. The ride is still pretty smooth almost like with the stock struts. Also, the handling seem to be better than with the stock struts. njmaxseltd is right, this setup is great. Sure, there's the hideous wheel gap, but that's the price to pay for a great ride. Also like I said before, with the stock sawblades, the wheel gap isn't that bad.
Old Apr 22, 2003 | 09:28 PM
MAXSRB's Avatar
Cumalot what year is your maxima and do you know which version Eibachs you have? I heard there are two types of drops when buying eibachs...i think i heard the springs manufactured after 99 were noticeably lower than the pre 99 eibachs....just wondering cause ive seen the difference and i would like the newer eibachs....(as you can tell im interested in your springs in case you do decide to sell)
Old Apr 22, 2003 | 10:56 PM
Cumalot's Avatar
Mine is a '96. The Eibachs that I have are the newest one. I only had them on for about 2 months. I bought them new from Tirerack.com
I'm definitely going to sell the Eibachs, just need to find a box for them first.
Old Apr 23, 2003 | 01:46 AM
bhmax's Avatar
Spring - H&R
OK, correct me if I'm wrong, but from what I've read your thinking would be:
H&Rs with all Tokico Blues would not be good because (the rear would be too bouncy/uncontrolled?).
H&Rs with all KYB GR2s would not be good because (the front would be too stiff?).
Old Apr 23, 2003 | 06:41 AM
njmaxseltd's Avatar
Dial in 2 up front & 3 in the rear and take it for a spin.
JRod28
Dec 29, 2023 09:56 PM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
twotonezed
Aug 16, 2015 11:41 AM
sc10692
Aug 9, 2015 09:37 AM
